100k miles on 4RUNNER
My 2002 4runner just hit 100k miles. any recommendations before i get my annual inspection. might as well get everything done at once.
i had the front and rear diff changed when i bought it at 65k miles.
Thanks!
-Jon
Thanks!
-Jon
Usually want to replace the water pump and timing belt around this time, spark plugs if you haven't changed them, check air filter, lube the U-Joints on front and rear drive shafts and give a good look over the under carriage for worn bushings etc.
thanks everyone!! i'll keep my 4rruner for a long time!
this list should get me started -
trans
t-case
Diffs
Timing Belt
Water Pump
Oil / Cam Seals
Plugs
how much are we talking to get these done at my local show. Just wanted to get an estimate so i set aside some cash.
-JON
trans
t-case
Diffs
Timing Belt
Water Pump
Oil / Cam Seals
Plugs
-JON
I haven't taken a vehicle in for any work in 8-9 years, but I would say that around 600-800 for all the work is a good estimate. If you are somewhat handy, you should be able to change your plugs, air filter, and change out the fluids. That way, you will only need to have them take care of the timing belt and water pump, and save yourself some money.
x2
you may want to seafoam it soon for good measure, of course before the new plugs!
MMA_Alex
25
04-18-2017 05:07 AM
Vargntucson
07-04-2015 12:15 PM
