$1000 for a Clutch?
Old 09-05-2003, 03:22 PM
rpeAMP's Avatar
$1000 for a Clutch?
Based on several recommendations here, I decided it was time to get a new clutch because mine was beginning to chatter. I called the dealer, and they want $1000 at MINIMUM for it. Is this normal or should I shop around?
Old 09-05-2003, 03:29 PM
Victor's Avatar
Don't have clues what shops charge. I did my own over a weekend.
Old 09-05-2003, 04:03 PM
Duffdog's Avatar
yes thats what the dealer will charge-- but a clutch shop could do the work just the same for a lower price, somewhere in the neighborhood of 500 dollars. shop around
Tim
Old 09-05-2003, 05:45 PM
sschaefer3's Avatar
Marlin charged me less than 400 for an Asian cluch and install. Resurfaced flywheel and new carrier bearing and plate. Actually I paid like less than 250 but the tranny was already out.
$1000 seems really high, try a different dealer or a Toyota only shop.
Old 09-05-2003, 09:25 PM
rpeAMP's Avatar
Thanks for the info.
I know that I technically don't need the extra gripping power that the Centerforce Dual-Friction clutch provides, but there's a shop locally that will do the work for about $500. Is this a good clutch? How would it compare to stock? If the consensus is that it will work just fine, I will just get that as it will be a lot cheaper.
Old 09-06-2003, 04:13 AM
Gadget's Avatar
The Centerforce dual friction thing is about the worst clutch you can get. I have one in my truck and it will not hold the power. If I am accelerating very hard and shift quickly into 2nd the clutch will not grab and the engine just revs up into the rev limiter every time.
I have a new ACT clutch ready to go in. I know a guy that is running much more HP then I am and it is holding in his truck. He has the same pressure plate that I am going to use, but he is running a 6 puck clutch, mine is a solid sprung hub clutch.
Gadget
www.GadgetOnline.com
Old 09-06-2003, 07:13 AM
Victor's Avatar
Marlin sells good stuff. His HD clutch feels stock but never slips. Machine the flywheel to .0026 instead of .0022 and it will grab even harder.
Old 09-08-2003, 09:54 AM
rimpainter.com's Avatar
I got my clutch installed with everything for $650 at the dealer.
$1000 is an absolute rip.
Old 09-08-2003, 10:40 AM
rixham's Avatar
Gadget - Where did you get your ACT? My Centerforce Dual Friction is a POS and I need to do something about all this slipping.
Old 09-08-2003, 11:12 AM
Albuquerque Jim's Avatar
rixham, I am looking for an ACT right now too. I went to their website ACT and gave them a call, they were happy to give me the numbers of a few shops that will sell to the public. The problem with their website list of dealers is that most of them are wholesale only.
I called Alder in Texas, (832)-237-8300 they quoted me a price for a 3rd gen of $420 plus shipping.
Old 09-08-2003, 01:57 PM
Dude236's Avatar
you dont like your centerforce dual friction? it might be different considering we have different engines. but mine was 440 for clutch and flywheel, not installed
Old 09-08-2003, 02:33 PM
I dont really see the point in recommending a high performance clutch to rpeAMP unless he plans on pushing some major power. And no offense, but I just dont see that happening with the 3.0.
rpeAMP, what are your plans for the vehicle?
I think you should go with all OEM parts. The stock clutch will last forever if driven properly.
Old 09-08-2003, 02:37 PM
rpeAMP's Avatar
I think I've decided with an OEM clutch, but I'm not going to pay $1000 for it (which is, according to them at minimum). I will even drive somewhere else to avoid paying that much.
Old 09-08-2003, 02:45 PM
Preston-
Get ahold of TOR (Todd) here on the boards, get the parts, then call around for labor chargers. That would be the cheapest way to go.
Good luck!
Old 09-08-2003, 02:46 PM
rpeAMP's Avatar
Thanks so much!
I just hope that the clutch doesn't go out on me before I get this taken care of...
Thanks again, everyone, for the advice!
Old 09-08-2003, 06:33 PM
Victor's Avatar
A high performance clutch does more than stand up to more power. It also prolongs clutch life with towing, four wheeling, and will hold up to future upgrades like a Marlin dual case. When in 4 low there is a tremendous amount of abuse to the clutch. Don't forget using the clutch and starter to start up steep hills so the truck doesn't roll back.
Old 09-08-2003, 11:28 PM
Cobb's Avatar
i had an ACT clutch in my pickup before i toasted it ant the tranny somehow. i had the solid disk and the i'm not going to the 6 puck. my 4runner is also going to be getting a solid disk from ACT until i swap to the LS1 and 4L60E tranny.
Old 09-09-2003, 05:58 AM
rpeAMP's Avatar
Well I got a quote from a local shop that will do everything (including labor) for $795 for a stock clutch. Seeing as that's the best price yet, I think I might go with it.
Old 09-09-2003, 07:37 AM
TOR
Clutch Quote
Hey man, whoever quoted you $1000 for the parts and install has been smoking some serious stuff!! We quote out $650 for the entire process and that is still a little high. Here is what I would think you would need worse-case scenario.
31250-35161-84 Disc $52.79
90363-12002-77 Throw out bearing $6.43
31210-35070-84 pressure plate $85.80
31230-35070-77 Clutch release bearing $31.89
Shipping: $10.00
All are remanufactured but are as good as new in my opinion. Let me know if you want to order any of them.
Todd
Old 09-09-2003, 09:07 AM
rpeAMP's Avatar
Todd,
Thanks so much for your reply.
I'm going to see if I can find someone here who will install this if I buy the parts from you.
I'll let you know very soon as I want to get this taken care of ASAP.
Quick Reply: $1000 for a Clutch?
