100 feet=burnt clutch
Old 12-31-2011, 03:06 AM
Darryl01088's Avatar
Let this be a lesson to anyone reading. Never let someone drive a manual tranny if you have any doubt. Long story short, I let my friend's 21 year old son back my truck out of the driveway and pull it back in the garage. Were talking a 100 feet max. Now my clutch is toast. When he was done, he asked me what the smell was...turned out he didn't release the parking brake and rode the clutch the entire time.
Truck is an 01 Tacoma, 4x4 with a supercharger. Which brings me to my question, is this more or less difficult than replacing the timing belt?
Old 12-31-2011, 03:26 AM
skypilot's Avatar
Well......
On an '88 its a ten hour job. two driveshafts, Xfer & tranny dropped; then flywheel cut & pilot & throwout bearing, disk & pressure plate replaced. Then you get to put it all back in.
Old 12-31-2011, 05:11 AM
waskillywabbit's Avatar
Probably no more difficult, just difficult in a different way.
:wabbit2:
Old 12-31-2011, 05:18 AM
aowRS's Avatar
From an access standpoint, I'd rather replace a clutch than a timing belt.
Andreas
Old 12-31-2011, 05:29 AM
Fossilized
Staff
dropzone's Avatar
did you ask the guy if he could drive a stick?
Originally Posted by skypilot
Well......
+ the speedo cable, TC & shift lever, console/surround/rubber boot, 4x4 & reverse light switch disconnect.
pick up a transmission jack from harbor freight...i use mine a lot...
service manual link http://ncttora.com/fsm/index.html
Old 12-31-2011, 07:41 AM
cman1's Avatar
first,you order a clutch kit from marlin crawler...then
Well......
Old 12-31-2011, 08:14 AM
corax's Avatar
I had my trans out in less than 3 hrs using only 2 ratchet straps, a bottle jack and the basic tools I carry in my tool bag (sockets, ratchets, extensions, wrenches). Replacing a clutch isn't hard, just make sure the alignment tool slides in and out easily once you have the pressure plate torqued on.
Old 12-31-2011, 08:39 AM
dntsdad's Avatar
This is step #1
Old 12-31-2011, 03:38 PM
CTRJ's Avatar
If your truck's clutch went out in that little of distance, it was on it's way out anyway. There is no way he smoked a good clutch in your driveway.
Old 12-31-2011, 03:43 PM
ThatGuy1295's Avatar
X2 Marlin clutch. Big difference
Old 01-02-2012, 12:19 PM
Thanks for the advice...i agree that the clutch was probably weak to begin with. A local garage quoted $600.00 for clutch disc, pressure plate, throw-out bearing. Funny, NAPA sells the same kit for $300. The garage will only warrantee the work if they buy the parts...but they are ordering from the same NAPA. They double the price of parts so they can provide a "warantee". Needless to say, I decided to take the truck back. I will do it myself when the weather warms up in the spring. This is not a daily driver so I can nurse it along.
Old 01-02-2012, 04:53 PM
totally a bro
Staff
vital22re's Avatar
the clutch may be Glazed. But you will most likely need to have the fly wheel resurfaced. It will be a full day project by the time you pull it apart, get the flywheel resurfaced, throw it all back together.
Old 01-02-2012, 06:29 PM
Fossilized
Staff
dropzone's Avatar
cool...but i can get mine out in less time and am happy with the $64 i spent at HF
works great for doing dual cases, axles...
Old 01-02-2012, 06:45 PM
fork's Avatar
I 'smoked' by clutch pulling a jeep out years ago. stinky smoke poured into and out of everywhere. i'm still using the same clutch in a different truck now. when it was pulled, it along with everything else was fine and well within spec. ymmv. its a centerforce if that matters
Old 01-02-2012, 09:00 PM
scuba's Avatar
Don't forget to replace the rear main seal while you're in there.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
4x4-runner
04-18-2017 09:08 PM
Dakotaneu
08-15-2015 07:24 AM
ViperTT
08-14-2015 05:27 AM
the1998sr5
07-16-2015 06:20 AM
Quick Reply: 100 feet=burnt clutch
