1" spacer for rear
1" spacer for rear
Last spring, i installed OME springs into my 98 4runner. I have a 4 cyl but used ones called for a 6 cyl. I now have a little bit of negative rake. I wanted to get some 1" or so spacers for the rear springs, but don't know where to get them.
Where's the best place to get a set?
http://www.cornfedsuspension.com or daystar makes 1.5" or I just added some 10mm OME trim packers to some stock bump cones + my existing OME 890's and got around 3/4" additional. For a spacer you're looking at $100, and for the trim packers/stock bump it's around $30.
A spacer made by ARB/Old Man Emu. The first picture shows a 1" Cornfed Aluminum Spacer on the left and a 10mm Trim Packer (yellow) on the right. The second picture shows the Trim Packer mounted on a coil.
Pics from Sonoran Steel
1 Post
OME has two trim packers.
OME80PF05 - 5mm
OME80PF10 - 10mm
Remember that there are 25mm per inch. That would make the 5mm TP ~3/16" and the 10mm ~3/8".
Since the rear coils are on a solid axle, you will only get the lift of the spacer. Unlike IFS where the spring is inboard on an A arm and you will get more lift from a spacer.
OME80PF05 - 5mm
OME80PF10 - 10mm
Well, according to my receipt, i installed OME906s and OME881s in my 4 cyl 4runner.
Its been a little less than a year, and i want it to sit level, if not a little raised in the rear.
It rides 100 times better than it did with the factory stuff. Put Trekmasters in while i had it apart.
Any suggestions?
Any suggestions?
Oh, i forgot-
My memory is failing me right now and searching isn't making my headache any better...
I remember hearing about PP products, including spacers. But I can't for the life of me remember what "PP" stood for and where to get those parts.
Any help on that info?
Thanks- i do appreciate it.
Oh, i forgot-
Paul
im running the cornfed 1" spacer w/ ome 891. its about 3.25" lift on my '99
imo, dont bother with trim packers for lift, they just squished down. i tried 2 10mm ones b4.
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
