04 4-runner Transmisssion VSC Trac VSC off lights - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-09-2005, 02:05 PM   #1 (permalink)
Unhappy 04 4-runner Transmisssion VSC Trac VSC off lights
I need some serious assistance I own a 04 SR5 4runner and I am in the army in germany. The germans do not make a 4 runner so dealer support is very limited. My 4runner check engine light, transmision light, vsc trac, vsc off lights are all on. The dealer has no clue. The codes C1201 and P0156 comes up in the computer. Can anyone please tell me what these codes are and provide some recommended solutions. The computer has been reset twice and the lights went off for about a week and now they are back on. This vehicle has only 9000 miles and I'm really frustrated. This is my first toyota and I think my last..
freemanc is offline
Old 03-09-2005, 02:13 PM   #2 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
Fix these two parts and then make sure you use a OBDii scan tool to clear the codes as this is the only way to reset it.
Good Times is offline
Old 03-09-2005, 02:14 PM   #3 (permalink)
Good Times's Avatar
Any toyota dealership should be able to make these repairs as it should be all done under warranty.
Old 03-09-2005, 02:34 PM   #4 (permalink)
I appreciate this, now I will have to see how long it will take this german dealer to get these parts.
Thanks
freemanc is offline
Old 03-09-2005, 02:38 PM   #5 (permalink)
Good Times's Avatar
you'll want them to diagnose the points of these error codes as it could stem from a single item that is triggering these errors. I don't have my service manual on me as I'm at work but I'm sure any toyota dealer would be able to follow the instructions on the service manual and determine what steps they need to run thru to determine what the faulty item can be.
I've personally never seen these errors as I even had to look it up so hopefully they'll be able to figure out the exact cause of the problem based on these error codes and order the correct item associated w/ the errors.
Good luck
Old 03-09-2005, 07:36 PM   #6 (permalink)
Andreas
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 184,XXX miles
2007 Volvo XC 90 AWD V6, Silver
1995 Porsche 993, Polar Silver
aowRS is offline
Old 03-09-2005, 07:39 PM   #7 (permalink)
89macrunner's Avatar
Quote:
Originally Posted by aowRS
Andreas
americans dont make 4runners eaither
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles
Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008)
2006 Mazda3 GT
2000 TRD Tacoma..Bought back and crushed
1988 4Runner SR5 V6 5 speed..sold
89macrunner is offline
Old 03-10-2005, 12:06 AM   #8 (permalink)
OK correction there is not a german spec 4runner for them to use as a guide or problems they have seen before.
freemanc is offline
Old 03-10-2005, 10:57 AM   #9 (permalink)
Good Times's Avatar
keep me posted on what you find. i have the 03 service manual so if they give you the run around i can try to take photos of the directions on how to diagnose the problem and send em to you or something.
good luck
Tags
2002, 4runner, abs, computer, light, lights, manual, owners, reset, runer, runner, toyota, trac, track, vsc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
VSC TRAC, TRAC OFF, CHECK ENGINE lights nathan gailey 95.5-2004 Tacomas & 96-2002 4Runners 7 04-09-2008 08:08 PM
Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems Writeups@YotaTech Electrical 0 01-11-2007 09:29 AM
TRAC OFF, VSC TRAC, ABS lights on mini_fly 95.5-2004 Tacomas & 96-2002 4Runners 15 05-12-2006 05:58 PM
VSC off, VSC Trac and CEL came on after putting in K & N Air Intake HenrySacto 95.5-2004 Tacomas & 96-2002 4Runners 9 12-30-2005 02:16 PM
VSC/A-TRAC Warning Lights broknlgs24 95.5-2004 Tacomas & 96-2002 4Runners 47 10-06-2004 11:35 AM
2009 InternetBrands, Inc.
