| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
04 2.7l idle knock issue
#2 (permalink) |
Thats funny cause I just had the same problem arise on my 138k mile 4runner and I don't know what it is either.
__________________
1997 Toyota 4runner 4x4, 2.7L, Auto, 146k miles, KC Slimlites, Bilsteins, OME 881/890s, Custom Westin Push Bar, Brembo/Hawk Pads, Yakima Gear, Midland CB, 265/75/16 Bridgestone Revos, Limited 5-spoke rims (Custom),Herculined Rocker Panels, Diff. Breather mod,Deckplate mod,4.56 gearing, Pioneer head unit w/Ipod connection and Sirius Sat. Radio. |
#3 (permalink) |
Mine is consistant across all engine temps and outside temps...im hoping maybe a sensor just got outta whack or something simple. Its just annoying cause its a 34,000 mile engine with a idle knock! hopefully we can both get some feedback ehh
#4 (permalink) |
Yeah! Bump!
__________________
#6 (permalink) |
i have an 01 Tacoma with about 76k miles on it.. doing the same thing... just a valve tap is all i got if we have the same thing... you get a haynes book tells you how to do it.. just have to adjust the clearance.. wont hurt anything just annoying ha
#7 (permalink) |
If you think it might be valve noise I suggest you have your valves adjusted. A lot of shops do not adjust the valves on those engines because it is a bit of a pain. If a valve clearance is off, the shim has to be removed, measured and replaced with one that is the correct thickness to bring the clearance back into spec. (Way more time consuming than your typical rocker style adjustment) If your valves are not within tolerance you will hear a bit of valve noise. Not sure if that is your case or not.
__________________
"WHY DO DRIVE THROUGH ATM'S HAVE BRAILLE?" |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Knock issue | ttr125mar | Maintenance & Repair Archives | 3 | 04-13-2005 03:50 PM |
| Rough idle on a '95 2.7L 4x4 | Blk04dr | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 03-20-2004 11:04 PM |
| '04 Taco w/2.7L engine question.. | Schuey2002 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-05-2004 03:15 AM |
| 2003/04 4.7L K&N Question | darktiger | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-03-2003 04:05 PM |
