03 Sunroof rattling fix
Guest
Posts: n/a
I posted this on another site, but thought I should also post it here in hopes that it might help someone with this problem.
This first picture is of the general area. Note that this fix needs to be done to both sides of the vehicle. And even though the sounds you might here sound like they are coming from somewhere else (much like mine did) this is actually where they are originating.
Guest
Posts: n/a
This next picture shows a close-up of the problem area. Note the round bar that runs down this channel. This bar controls the movement of the wind deflector. So it moves forward and backward down this channel. The reason I believe that some people are having this rattling problem and others are not is due to the fact that if the sunroof is not adjusted just perfectly, than this bar has some load on it, which causes it to flex slightly bringing it closer to the channel edge.
I'm wondering it a piece of the velcro felt with adhesive backing placed in the channel for the bar to rest on would work? I haven't looked at mine yet, but the rattling is starting to get to me. And I can just imagine what I will go through if I ask the dealer to 'fix' it.
WhiteSR5's ROCKS! The fix really works! I did the fix earlier today...
i posted a reply on another forum but just wanted to let all you yota heads that it cost less than a dollar and took only a few minutes... so far so good, no rattles...
cheers
cheers
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
01-04-2016 10:47 AM
