02 Type aluminum skid question
Old 06-12-2004, 08:24 PM
dbikeman's Avatar
I have been checking out the sport edition skid plate for my 4runner. My question is where does it mount to? I need to know cause I have a 98 but have a 99+ style bumper. If it mounts to the bumper assembly I believe I need to the the actual 4runner one, but if it mounts somewhere else I might be able to get the Taco one. Thanks for viewing!
Old 06-12-2004, 09:35 PM
Guest
fourunnabilly's Avatar
Hey bro, I am clueless on this one. Figured the least I could do is give you some S**T and bump ya up. Peace.
Billy
Old 06-12-2004, 10:55 PM
bbkoz's Avatar
It mounts to the tow hooks. You just unbolt the hooks, mount the brackets for the skid plate back up to the tow hooks. Then bolt the skid plate to the mount plates. I have one on my Taco, and I know it's the same for the 4Runner. Sorry, but I'm not sure on the 4Runner fit. There might a slight difference due to the bumper change in 99...
Old 06-13-2004, 05:24 AM
4RunnerFever's Avatar
It mounts to the tow hooks, but you have to reverse the brackets to make it fit a 4Runner. You'll only have two of four bolts attaching the skidplate to the bracket, but it is solid as a rock anyway. My website has a pic or two.
hope this helps
Come to think of it, it might install correctly with the longer 99 bumper (?)
Old 06-13-2004, 06:23 AM
Andrey's Avatar
Yeap, exactly same thing on 4Runner. Just unbolt tow hooks, mount brackets with skid plate, bolt tow hooks back.
I can take some pics of my skid plate if you like. Let me know...
-- Andrey
Old 06-13-2004, 08:36 AM
dbikeman's Avatar
Pics would be great! Im not worried about the 2 bolts and not 4 either. I want one for looks only.
4runnerfever, i noticed what you have on your rig and mines gonna seem like a copy in a way. I want the 01 tails and we both have the new hood. I hope to get the OME lift though and I cant decide on 285s or 265s. Im going for looks on the lift so im trying to keep that in mind.
Old 06-13-2004, 04:03 PM
yea, I'm in it mostly for fun and for looks. I went with the Revtek lift for that reason. It was a straight forward install and the 285's only rub if you've got the thing fully locked in a tight turn. They really don't rub enough to do any damage.
You're rig looks real good!!
Old 06-13-2004, 09:09 PM
dbikeman's Avatar
Thanks! Yeah I hope to do the lift and get Mickey Thompson classic II's as well. How does your revtek kit ride? The only reason hadnt planned on going that route was that Ive heard the OME setup rides great and I really want that.
Old 06-13-2004, 11:01 PM
BajaRunner's Avatar
I was planning on buying one of these skid plates as well.
Does it come with the mounts, or do you have to buy them seperately? Will this skid plate work on a 96?
Old 06-14-2004, 04:48 AM
calg3's Avatar
If you still have the stock front bumper just get one of the Tacoma skid plates off of eBay, it bolts right on. Comes with brackets and bolts. Like stated earlier, just unbolt your tow hooks on the front, the brackets go on under the tow hooks and then the skid plate attaches to the brackets with the 4 bolts provided. That is what I have on the front of my 96.
Old 06-14-2004, 05:24 AM
lee
lee's Avatar
i want one really bad, but:
a) do not have the money at the moment for a visual accessory
b) am unsure of how it will fit with regards to my brush guard...
Old 06-14-2004, 08:31 AM
In my opinion, dbikeman, the Revtek lift rides the same as stock. It did not improve things, but it did not make it worse.
Hope this helps
Old 06-16-2004, 01:37 PM
Tman100z's Avatar
SO are you guys saying the tacoma skid plate will fit with a few easy mods?? BTW I have a 2001 runner sport ed. I see quite a few of them on ebay but none are ever for the runner.
Old 06-16-2004, 01:58 PM
bradym239's Avatar
Hope this helps
4RunnerFever,
Your rig's "anthracite", right? I had a '97 like that. I miss that color. It is by far the best production color for a vehicle that I have ever seen. Sweet ride.
Regards,
Brady
Old 06-16-2004, 03:00 PM
dbikeman's Avatar
Tman, the tacoma skid only works with 96-98 4runners. For your 01 you will more than likely need the actual 4runner skid.
Brandy, your right I love that mine is athracite
Old 06-17-2004, 03:40 AM
bradym239 - thanks man, anthracite is great (especially when it is clean)
Old 06-17-2004, 08:46 AM
bradym239's Avatar
Yeah, I remember that being a bit of an issue. I've got a 2002 SE that's sunfire red and it seems to not be all that forgiving with dirt, either.
Regards,
Brady
Old 07-15-2004, 09:56 AM
terrytcl's Avatar
do you guys know where I can get a 2001 aluminum skid plate?
how much do they run?
my 1999 has a two piece skid plate. one right behind the radiator and one
that protects the front diff. will the 2001 skid plate cover all of it?
or just the front most area?
thanks!
Old 07-15-2004, 10:53 AM
calg3's Avatar
thanks!
Just the front most area, ends at your first existing one right behind the radiator.
Old 07-15-2004, 02:03 PM
terrytcl's Avatar
thanks for the reply.
do you know if i can just get the skid plate?
or do i need additional hardware to have it mounted?
Quick Reply: 02 Type aluminum skid question
