02 Sport lights/wiring help
I am adding some lights to my yakima rack and I need some help wiring the relay. Where is a good place to get 12v to switch the relay on? under the dash is best, so what color, or what to tap into?
thanks alot!
thanks alot!
A fuse tap is somthing you crimp on the wire then jam it into an open spot on the fuse panel, or remove a fuse and use its location.
Well tap it into the fuse box if you want or go staight to the battery, go to your local parts store pickup a rocker switch, find a good area to mount the switch and wire her up, take some pics too!
Big Little Bear
230
11-13-2023 11:42 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
