02 sensor replacement - 01 TACO Dbl Cab - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-14-2009, 01:22 PM   #1 (permalink)
Baloo's Avatar
Send a message via AIM to Baloo
I got busy (a little lazy too) and took my 2001 Dbl Cab in to have my Magnaflow muffler reinstalled, an hour or so job. 3 days later when I get the truck back I get going down the road and about a mile I throw a P0141.
Of course the installer tells me anytime you mess with the 02 you risk this happening however since they clamped rather then welded it I am not sure why the had to remove it and the pipe.
Anyway, my question is: The culprit is the sensor AFTER the CAT. Taking a quick look in the lot I see the wires go up into the body through a grommet in the underside body. Is the plig right on the other side of that grommet? Do I remove the whole grommet or just work the wires through it in place.
Lesson learned; whenever possible, DO IT YOURSELF?
__________________
2001 Toyota Tacoma DBL cab.TRD Off Road.
ISR & Deckplate. XM/Sirius. VHF/UHF/HF Radio, Laptop & GPS Mounts. FlexFuel Conversion.
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out screaming "WOO HOO, WHAT A RIDE !!"
Baloo is offline
Old 11-14-2009, 04:21 PM   #2 (permalink)
hurricanes99's Avatar
Not sure about the Taco, but on my 99 4Runner there is a plug about a foot up from the sensor. I ordered one and should be replacing mine in the next few days. I don't think you should have to go all the way into the interior to replace it.
hurricanes99 is offline
Old 11-15-2009, 12:50 PM   #3 (permalink)
mt_goat's Avatar
On the 01 Taco ext-cab I had the plug to the rear sensor is under the carpet. IIRC I just removed the passinger side door sill trim and lifted up the carpet and found it. Can't remember if I removed the grommet or just worked the plug through it.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is online now
Old 11-15-2009, 01:32 PM   #4 (permalink)
Baloo's Avatar
Thanks. The part hadn't come in yet so wasn't sure how long the pigtail would be, Was trying to decide if I was going to do it or insist they pay for me to have someone else do it after my experience.
I think it will be the former so I know it is done right.
__________________
Baloo is offline
Tags
02, carpet, remove, sensor, taco, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
