02 radio
there are 2 kinds w/c i noticed...a yellow and a white plastic covering for the output wires.
the yellow covered one seems like is used for the double din,higher end stereos that come from the factory.
reason why i noticed..i installed a 98 double din cd/tape player combo on my 2000 and it came w/ the yellow one(2000 came w/ the white one) and the plugs didnt match.
what i did was swap amps on both trucks as the power supply for the amp itself is all the same...
radio works perfectly..
i would say you can run the 02 radio on the 98 but to be safe...swap in the 02 amp as well...
just be careful buying the correct amp for your radio...if you have the double din type most likely you'll need the yellow pigtailed amp vs the white one(mostly for single din type radios)
best thing to do is post a pic of ur radio on here front and back.
here are the 2 types of amps(not mine):
white pigtail:
http://cgi.ebay.com/OEM-TOYOTA-FACTO...item4393bcd843
yellow pigtail:
http://cgi.ebay.com/ebaymotors/AMPLI...fAudioQ5fVideo
i still have a yellow one hook up to the 4 runner so i need a white one like this http://cgi.ebay.com/ebaymotors/99-02...fAudioQ5fVideo
the connection is the exact same thanks for all your guys help
kawazx636
10-06-2021 03:03 PM
mct75
08-22-2016 01:24 PM
zombie_barbarossa
10-02-2015 10:54 PM
tazman1972
11
09-28-2015 10:32 PM
