'02 4Runner and a Diff Locker?
Old Oct 20, 2006 | 02:53 AM
914runner's Avatar
I am thinking about getting a '02 4Runner Sport Edition, and I have a E-Locker rear axle out of a '96.
If I was to put the E-locker rear axle in the '02 will this mess with the A-trac?
Thanks
Old Oct 20, 2006 | 03:00 AM
AH64ID's Avatar
You would have to find a way to get the wheel speed sensors on the new rear axle...
Old Oct 20, 2006 | 03:04 AM
914runner's Avatar
Where are the sensors located on the '02 rear axle?
Old Oct 20, 2006 | 03:13 AM
914runner's Avatar
I just did a quick search, and it looks like the ABS sensors are on the drum brake backing plate? Is this true?
If so couldn't I swap the '02 brakes onto the '96 bare housing and be good to go?
Thanks
Old Oct 20, 2006 | 10:33 PM
914runner's Avatar
Nobody knows? I did a search but couldnt find an answer.
Old Oct 20, 2006 | 10:39 PM
Elton's Avatar
the search button is very picky i cant find stuff half the time
Old Oct 21, 2006 | 01:59 AM
914runner's Avatar
I agree. That why I ask really specific questions like this to help others with the same question. That way when someone else searches they can quickly find the answer and not have to sift through a 20 page thread to find their answer.
Old Oct 22, 2006 | 07:36 PM
arjan's Avatar
Doesn't the atrac use the same sensors as the abs? If so you can just use the same sensors. I think all '96 and up 4Runners have ABS.
Old Oct 22, 2006 | 07:42 PM
spaugh's Avatar
my 96 doesn't have ABS
Old Oct 22, 2006 | 08:25 PM
rcars4life's Avatar
I have a 96 with abs, tell me what i'm lookin for and i'll take a look tomorrow. I have no idea what a speed sensor looks like
Old Oct 22, 2006 | 08:44 PM
toyotaoffroad91's Avatar
correct me if im wrong but cant you just swap the third member
Old Oct 22, 2006 | 09:29 PM
arjan's Avatar
Interesting, I didn't realize abs was an option on the 3rd gens. The speed sensors are between the brakes and the springs on top of the axle housing. There is one on each side and there are wires coming from them going up to the frame at the differential.
Old Oct 23, 2006 | 02:41 AM
AH64ID's Avatar
I too thought when the 3rd gen came around they all had ABS?? I know in 95 all v6's had abs, but 4cyls didnt... is yours a 4cyl?
Old Oct 23, 2006 | 09:06 AM
spaugh's Avatar
mines a V6. To be honest, I don't know what to look for in refernce to the ABS, but I had the truck at a toyota yard and the guy there was looking at it and said you don't have ABS so I assumed I don't have it. Also, Ive never had it do the click click click click in the dirt when I lay on the brakes. Tell me what to look for and I will look for sure.
According to this, the 4wd non SR5 was optional ABS, but mine is SR5 which should have been standard. If someone tells me exactly what to look for Ill check for sure.
http://autos.msn.com/research/vip/Sp...Runner&trimid=
Old Oct 23, 2006 | 09:38 AM
pat161's Avatar
Just look for the light on startup, if you have ABS it should light up while the system is being checked or whatever. ABS was an option on 4 cylinders, my 00 had ABS while my buddies 98, set up almost the same, did not. Not sure about the V6 models, but I do know that ABS was always available on 3rd gens. On 99 and up ABS equipped models also had DRL's, so no DRL's means no ABS on later years, 01 and 02 all had ABS.
Old Oct 23, 2006 | 10:41 AM
spaugh's Avatar
what is DRL?
Old Oct 23, 2006 | 10:57 AM
NPE701's Avatar
Daytime Running Lights
Old Oct 23, 2006 | 04:58 PM
914runner's Avatar
NPE701 - Do you have any pics of your rig? I really like that color!
Old Oct 23, 2006 | 08:21 PM
Flygtenstein's Avatar
If it is only ABS dependant and you axle has ABS, then swap the whole axle.
3rd Gen ABS is at each wheeld, an enlarged area close to the backing plate that has a plug the size of end of a cigar.
If you modified the housing, you could plug it in.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
A2theK
Jul 12, 2015 10:46 AM
AaronM
Jul 8, 2015 07:15 PM
