| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Guest
Posts: n/a
01 Tundra CEL, what else could it be?
#2 (permalink) |
sounds like you are just toosing parts @ it. Hoping it will get fixed. Wasting money.... Just take it to a shop that will scan it and tell you what it really needs.
Check the blinker fluid, if thats good, then tighten the piston return springs, if that is still not it. Then I hate to tell you. But you have a bad muffler bearing.
__________________
Y2K 4runner. With a bunch of stuff. Last edited by mark_fit; 12-02-2005 at 01:26 PM. |
#3 (permalink) |
Guest
Posts: n/a
First off, I'm not just tossing parts at it, I've pulled the codes each time, then checked connections, checked for shorts with a multimeter then proceded accordingly.
You know this is the kind of response that pisses me off to no end, I post up all the info, what I've got, what I've done, and what has already been addressed and or replaced, and I get a wise ass suffering from rectal-cranial-inversion reply. Oh, and just for future reference it's spelled "tossing" I couldn't find anything in the dictionary for "toosing". Having been a mechanic for 10yrs before I went into the tech field, I know what I'm doing and how to go about it. So why the Jerk off infantile response to my post? Stumped you too obviously, so this is the best you can come up with huh? I had alot of respect for this place, I admired the skills & abilities of alot of the members with willingness to assist anyone anytime with their problems. But then one ing intraverted smartass has to spout off thus changing my opinion of this place. As always *SMILE* -a.meuse |
#4 (permalink) |
It probably would have helped is you said "I got code xxx so I replaced the MAF", etc. Knowing the progression of the codes would help out the experts here quite a bit, I would think. I am as surprised as you are that nobody has come in with a solution.
I'm not the CEL guru by any means - did you try PM'ing or emailing Gadget? Just my $0.02...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#5 (permalink) | |
Quote:
Ok. Teacher sorry about my spelling. I was using my blackberry again to view yt. So a mechanic for 10years?? What did you work on that you can't figure this out. Model T's. I am the kind of person that would usually help people out. You know I wrote what I did to really give you a bump of thread. My family has a 2001 tundra, 2000 4runner, 2002 4runner and a 99 accord. None of them ever been to the dealership after the warranty exp. I am a BMW master tech and could figure out 99.9 percent of the time what was the problem. So there!! If you were local I would prob. Offer to help you out one night bc I happen to have a scanner. But being the way you are. Good luck tundra dude that is looking for help on a 4runner board. Check some toyota Tsb and you may saved some money. I bet I found your problem.
__________________
Y2K 4runner. With a bunch of stuff. |
#6 (permalink) | |
Quote:
I can understand where Marc is coming from, since your original post was rambling. I'm with tc and believe that if you described your progression of CEL codes and troubleshooting that we might be able to help you out. Considering I don't have the Toyota reference manual in front of me, and that you have pulled the code, what does the P0171 code say ? Is it running lean ? Have you checked your O2 sensors ? With 120K on the originals, I wouldn't be surprised of one of them were starting to fail. But that is just my web-wrenching... It looks like a good time to start doing some re-search on this issue. Good luck ! Steve
__________________
'03 V8 4Runner 4x4 SR5 *OME Lift*MV-50 OBA*Yak rack*Lightforce 170s* |
#7 (permalink) | |
Quote:
What did it fail for? CEL? So if I understand correctly, you had a P0171 at one time. Any other codes? You then replaced the MAF, O2, TPS, Spark Plugs, Air filter, fuel filter. Were they all new OEM parts (besides the air filter)? The O2 could be the problem (on a 2001 it is an A/F sensor in front of the cat as you mentioned), but I wanted to make sure we know all the cards before making any diagnosis.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 01 ISR mod - CEL now on | Baloo | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-10-2007 03:27 PM |
| Built '01 Tundra | Joe | The Classifieds GraveYard | 20 | 10-29-2006 10:06 AM |
| RECALL - 01-04 Tacomas, 01-02 4Runners, 02-04 Sequoia/Tundra. Updated 7-27-05 | Sparman | 95.5-2004 Tacomas & 96-2002 4Runners | 96 | 10-05-2006 10:03 PM |
| '01 Taco MAF sensor / System Lean CEL troubles... | MtnGrown | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-17-2006 06:21 PM |
| 01 Tundra, maybe? | Kerr | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 12 | 10-21-2004 07:54 AM |
