01 gauge cluster in 2000
hi.. new to the forums.. did a search and couldn't find an answer... i just put a gauge cluster from a 01 4runner into my 2000.. i had to change the circuit board on the back, so the plugs would match up... well.. everything seems to work, except
my temp gauge is always on hot,
the abs light stays on,
the parking brak elight stays on whether or not the brake is set,
and finally, when i turn on my hi beams, both signal indicators light up instead of the hi beam indicator
any ideas? or do i just need to find a cluster from a 2000?
thanks in advance
thanks in advance
haha.. thanks... i knew it was different.. but it came as extra parts with the truck.. and i needed a cluster to use... so i figured it would be temporary for now.. just wanted to see if there was anything i could do to make it work while i was looking for a cluster from a 2000.
thanks for the help!
jacked_72
09-14-2015 03:31 PM
