'00 Rough idling Taco
Old 09-19-2007, 12:42 PM
AppleJack's Avatar
I've been working on my brothers '00 Taco 3.4 with a manual. He complained of a rough idle, felt like it was miss firing around 1700-2000 rpm and smoothed out after 2300 or so. Changed the plugs checked the PCV and cleaned the MAF. Ran smooth as silk yesterday. Today it's rough again. Previously there was no CEL but today there was and it came up that the coil pack for #1 and #6 was bad. Changed that and it's still running rough. CEL back on says the same thing. What else could it be. I did do a search but nothing else quite matches this problem, at least I don't think they do.
Old 09-19-2007, 01:07 PM
mokai's Avatar
Try checking the plug wires for worn spots and double check that they are connected firm..Could just need new wires..Just a thought..
Old 09-19-2007, 01:27 PM
AppleJack's Avatar
I'll check that, but would that give a code for a bad coil? Faulty codes do happen I guess.
Old 09-19-2007, 03:28 PM
GOH10 Runner's Avatar
My Moms LC did that and it was a bad injector.....something to look at.
Old 09-20-2007, 03:24 PM
AppleJack's Avatar
What things can cause the a code indicating a miss fire in #1 and #6 other than a bad coil pack, plugs or wires? Because I've already changed those. If there was insufficient fuel reaching that cylinder could that show up as a miss?
Old 09-20-2007, 03:57 PM
Yota Doc's Avatar
You can run out of fuel and it will show as a misfire. Try checking the fuel psi, it couldn't hurt. Fuel pump could be taking a crap or full fuel filter restricting flow just enough. If u check the press make sure the psi doesn't drop when you cut the key off. That would be a bad valve in the fuel pump. Seen it a bunch. Be sure your wires are good. Good luck.
Old 09-20-2007, 05:44 PM
AppleJack's Avatar
Thanx for the help I'll check this out and report back.
Old 09-20-2007, 05:49 PM
4Runner202020's Avatar
mine had a similar problem i changed my timing belt and it fixed it. check that out...
Old 09-21-2007, 05:12 AM
AppleJack's Avatar
Yeah the timing belt and water pump were done about a month ago.
Thanx anyway.
The good news is that though it's only been a day.....so far so good.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
montanatruck
02-26-2017 07:07 AM
wafoogalla
11-02-2016 11:02 AM
Quick Reply: '00 Rough idling Taco
