00 4wd question
Old 07-08-2009, 10:12 AM
benhamean's Avatar
00 4wd question
So I got a 00 4wd runner. no pressbuttons on anything - just the shifter. I am curious how the 4wd works and what lockers may/may not be on the truck. So I dont think it comes with any diff lockers factory. Does this mean that if 1 wheel slips then none of the rest will turn? Or does one wheel on front and one on rear have to slip before you have no more power to your wheels?
Old 07-08-2009, 10:40 AM
scuba's Avatar
http://en.wikipedia.org/wiki/Open_differential
Old 07-08-2009, 10:57 AM
benhamean's Avatar
Been there, read that. What about an 00 4runner? Any factory lockers? Thanks for the help.
Old 07-08-2009, 11:15 AM
scuba's Avatar
Yes they have factory rear lockers.
Have you used the search button at all?
Old 07-08-2009, 11:20 AM
benhamean's Avatar
Yeah, I was on here about 3-4 hours searching for it the night before I bought the truck. Found some threads about 2002's and 2001's but both those systems have a pushbutton 4x4 button which I read apparently has a center locker. By they way, thanks again. I look up everything before I post - just couldnt find anything specific on 00's.
Old 07-08-2009, 11:24 AM
scuba's Avatar
Ok, well if you have a locker the button will be to the left of the steering wheel.
If you dont have a limited 4Runner you probably dont have it
Search harder.
Old 07-08-2009, 11:37 AM
benhamean's Avatar
Yeah, no limited. And no pushbutton - so no locker?
Not sure how to "search harder". I searched for "diffs" "4x4 lockers" "diff lockers", "00 differential lockers", "00 4x4", "00v4wd". But thanks again for the help. Sorry to be a bother.
Old 07-08-2009, 11:45 AM
scuba's Avatar
http://www.nwtoys.com/search/google/...tesearch=#1136
This thread has some ok info
so does this one
https://www.yotatech.com/forums/f2/l...r-diff-157538/
Click search, Click advanced search, type "Stock Rear Locker" and then select the 95.5-04 and 96-02 Taco's and 4Runners and that should narrow the search results down some.
No need to apologize
EDIT : Its been 5 years already ?
Mmm more like 1.5...
DeathCougar
04-01-2018 11:29 PM
makemusic116
08-02-2015 04:40 AM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 00 4wd question
