RBx 1988 4Runner Build-Up Thread
Old 06-23-2011, 06:54 AM
  #541
SHAGGY21's Avatar
Hey RB I got a question. I was looking at ur cross over pipe delete and was just wondering what happens if u have to pull the engine. As u welded the pipe behind the flange on the down pipe.
Old 06-23-2011, 07:01 AM
  #542
RBX
RBX's Avatar
then i disconnect the cross-over and down pipe as one piece. The crossover pipe has some type of flex joint in it, and it flexes alot more when the heat sheild welds are removed when i cut it.
Honestly my thought was this engine is coming out, and i will be running the TDI, so a new exhaust is planned for that. If this engine lasts another year i will be stoked!
Old 06-23-2011, 07:22 PM
  #543
Outsane's Avatar
So did your son finish it?
Old 06-24-2011, 03:01 AM
  #544
RBX
RBX's Avatar
^^^ No, i wish. He did quite a bit, put in a solid 4 hours. But ran into a few issues.
1. Front drive shaft is too long, and Toyota changed the flange hole spacing in the 90's, so i need to see if i can swap flanges on t-cases.
2. Can't bleed clutch, I think the MC is shot, i can't draw any fluid thru down to the slave cylinder with my pneumatic bleeder, but i could bench bleed it?
3. T-Case seems to be stuck in H2, can't figure this one out yet.
Old 06-28-2011, 04:39 AM
  #545
RBX
RBX's Avatar
Drove the truck with the new 5spd in last night, definitely more peppy and powerful the the life sucking a340 that was in there. Fan controller not working so we just did a quick HWY blast to run thru the gears.
Fabbed a cross-member, used the ends from the donor...
fabbed x-member from 3/8" steel, 2"x4" box cut into wedges, and the factory frame mount points:
Clearance, sorry pic is a little dark(10* clocked transfer case)
I tried to gain as much clearance as possible with transfer case x-member. I plan on getting a nicer transfer case mount since mine is actually worn a bit. Due to this i have a very close clearance issue with one bolt on the transfer case drop, but nothing to stop me from driving it.
Yesterday my fan controller came back, so i was able to install that aswell, but i can't seem to get it functioning correctly at the moment
Old 06-28-2011, 08:03 AM
  #546
Outsane's Avatar
nice.. so whats the plan for the fan controller?
I'm going Arduino!
Old 06-28-2011, 08:07 AM
  #547
irab88's Avatar
@outsane: why didn't i think of that! ingenious! i gotta see your set-up
Old 06-28-2011, 08:15 AM
  #548
Outsane's Avatar
Here is what I have so far
http://www.youtube.com/watch?v=K6PkCfrjUbc
I'm I need to learn how to make menus... then its game on..
Old 06-28-2011, 08:19 AM
  #549
irab88's Avatar
hoover dam! (no yoo-toob here at work, i'll see it in a bit)
i'd love to do something like that! arduino ftw
Old 06-28-2011, 08:22 AM
  #550
Outsane's Avatar
then help me out with the menu stuff..
I'm sure we could sell a couple of kits!
Old 06-28-2011, 08:29 AM
  #551
RBX
RBX's Avatar
i just need to run a few tests on the controller, volt meter stuff.
Old 06-28-2011, 08:45 AM
  #552
irab88's Avatar
sweet... open source fan control
[/hijack]
Old 06-28-2011, 08:48 AM
  #553
JBurt's Avatar
Ok educate me, what is the advantage of having a fan that you can control as opposed to one that kicks on when your engine reaches a certain temp? Great work with the swap by the way.
Old 06-28-2011, 08:53 AM
  #554
irab88's Avatar
it's not so much manual control as it is adjusting the automation. if the fan doesn't need to kick on until 190*, but it's set for 185*, then it's on for longer than needed. and if you have a 2-speed fan, you can control how often and when the high-speed fan comes on. using a micro-controller, such as the arduino, lets you change virtually any and all parameters of fan control
Old 06-28-2011, 08:57 AM
  #555
xxxtreme22r's Avatar
Automated and Toyota should not be used hand in hand. haha just kidding, that's a pretty trick setup. I'll stick to my on/off fan toggle switch. lol.
Old 06-28-2011, 09:10 AM
  #556
JBurt's Avatar
Thanks irab. That helps
Old 06-28-2011, 11:45 AM
  #557
irab88's Avatar
@ outsane:
http://www.arduino.cc/cgi-bin/yabb2/...m=1233535986/7
http://www.coagula.org/content/pages...isplay-arduino
http://forum.allaboutcircuits.com/sh...364#post330364
http://www.bing.com/search?q=arduino...ox&Form=IE8SRC
i want to play with an arduino now!
Old 06-28-2011, 11:57 AM
  #558
RBX
RBX's Avatar
Arduino, very cool, but which one do you buy for a fan controller?
Oh, nice avatar Ian!
Old 06-28-2011, 11:59 AM
  #559
RBX
RBX's Avatar
actually, i just thought about possibly using something like this when i go to the TDI swap, since the ECU passes signal for alot of functions not necessarily engine specific.....hmmm.
i will predict i will waste massive amounts of time....massive.
Old 06-28-2011, 12:39 PM
  #560
irab88's Avatar
that's the beauty of arduino... pick one! they all do the same thing, just differing in shape, voltage (3.3 or 5), and i/o pins. the mega has a bunch of pins and memory, but the micro is the size of a flash drive
thanks. brandon took that one. that was fun. and the truck never really got too dirty
Quick Reply: RBx 1988 4Runner Build-Up Thread
