karlm-c's 1986 2WD Pickup Build-Up Thread
So the latest thing I've done, besides constant tweaks to carb and clutch (I just can't seem to get my clutch adjusted perfectly) was to build my kit. Tool kit, air pump, MSR stove, fuel and a pot, mounted an axe and threw my folding army shovel in there. It all goes well with my complete bottle jack kit
I still a harchet i wanna mount somewhere in here too
after the snow yesterday, which became wet and slushy, I've been thinking about getting a set of chains. 2, for the rear.
anyone have experience with these? I was thinking of getting these
QG1850 with the rubber tensioner. They have good reviews and look good.
https://www.amazon.com/gp/aw/d/B000BR8U9A/ref=ox_sc_act_image_2?smid=ATVPDKIKX0DER&psc=1
for 70 bucks can't really go wrong, right?
70$ Is cheaper than a tow., and probably AAA
A True trac is about..
Seven pairs of chains, Six AAA's, Five tow chains, Four tow trucks, Three flat beds,, Two caved in grilles, And a Detroit truetrac
... yes sing it to the 7 days of christmas, I couldn't resist. The math is sound for the first and last one mostly
My two wheeler has a set of chains under the seats, but I have never put them on. Once you are stuck it's kind of too late, since you can't roll over them to put them on and I usually only get stuck in my parking spot or at the end of the driveway because I got plowed under. I wouldn't mind a limited slip diff one bit, it's a very good upgrade, nothing infuriates me more than being stuck and having to keep switching from one side to the other clearing enough room to get the momentum to get back on top of the cruddy ice.
#25
And, I think that my truck will look badass with chains on it. I drive back roads to work in the best of weather to avoid the highway, so going 30 to work will be easy.
#26
While I say that, the more I look around on here, on instagram, on other forums and image galleries, I will definitely be getting a 1980 4x4 at some point. And a FJ60 Landcruiser at some point. So while I like the 2wd for my daily driver, now that I understand mechanics more and are getting better at wrenching, I will be going 4wheel at some point. If my goals of opening my own shop actually happen, all of this should be easy!
