help! i cant get the cam bolts out of my 1994 yota pickup 4x4
hey i am piting a 4-5" suspension lift in my 94 yota can i cant for the life of me get the blots out of the lower control arm.
Yes the tightest bolt on the truck i believe. my 1/2 ir super gun wont even touch it. it wil pull the crank bolt tho. What ive done is use a large chain wrench. i then wrap an old t belt around the cam gear. cut the belt to wrap around the gear once. then put the chain wrench around the gear. The belt prevents gear damage. get a piece of pipe that will fit around the chain wrench handle. the pipe i have is like 3ft long. then put your breaker bar on the bolt. i use a pipe on the breaker bar also. even with this it can still require lots of effort.
duckhead
07-17-2015 04:45 AM
