Green Bast 4Runner 7MG-TE SAS build
#25
#29
no they sure aren't bracketed in that picture haha I was just excited to get the axles underneath and took some pics. I added bump stops for the top shackle and will be doing a brace to stop them from becoming a double jointed death trap shortly.
#30
#31
Have you flexed your front suspension yet? It seems that the springs would hit the drag link under compression on the driver side with the steering box mounted like that.
#32
yes it hits, haha when i ordered the steering components i really didnt know how everything would line up and made the mistake of going with the drop pitman arm. Flat one is on order and should be well out of the way
#33
#34
But its still a double shackle... Ugh.
I second the axle needing gussets! Dont put all that work into it just to have it bend.
If you rotate the steering box back the other way, youll fix that rag joint angle and still be able to use your drop arm.
Nice work on the 1/2 doors!
#35
^^^I was going to suggest the same thing on the steering box, if you took the top 2 bolts out and pivot the steering box the other way (counter clockwise) it would fix the rag joint, you'd have to relocate your top mounting holes tho, (might think about plating/reinforcing the frame at the steering box also as it will be a high stress area once your running bigger tires, you can make your own or buy TG or others for around $50. Nice work on the half doors, cool build so far, look forward to seeing some more!!!
#36
Are they the sky shackle? They have a little tab on them to stop them from going the wrong way...
ya Im having second thoughts about the double shackle setup, I dont like the idea of them unloading when you are in a precarious position. they seemed like a good idea when i read about them originally but they might get scrapped.
I will rotate the steering box and see if i can get a better angle and burn some gussets on today!
#37
Thanks guys! Im pretty happy with the way the doors turned out.
#39
1 Post
I was thinking about doing that with my steering box too. but I'm might just go with a flat arm instead of the drop arm. Sounds like you ordered the flat arm but ended up rotating the box instead, want to sell the flat arm?
How much room do you have in between your rad/fan and the balancer on the crank?
With my front mount intercooler, rad and electric pull fan I have 1/2" of room from the fan to balancer...and your intercooler is much farther back than mine is.
#40
I probably have 1"maybe a bit more I will measure tomorrow. did you use the original transmission mounts or did you move everything back when you did your swap?
that pic with the intercooler was before i had the engine in and realized just how little room i was dealing with, no way it would fit like that. as of right now its looking like i will go with a top mount intercooler. I hear of some guys running straight off the turbo but i cant see that heat helping the longevity of your engine.
