1988 Toyota Truck Fuel Injection System Removal
I was wondering if anyone had any tips or trick for removing a fuel injection system from one engine and installing it on another engine? I can't find any information on 1988 Toyota Truck fuel injection systems. I am trying to remove the entire, intact system (wiring harnesses) and moving right over to another engine. I am looking for any advice at all. Is there even a way to remove the entire system without dismantling it? Any video, schematics, books, etc would be greatly appreciated.
Thank you
Thank you
Thank you
Thank you
As long as its the same type of motor. Its really just plug and play, take a lot of pictures/label everything and you should be fine.Use your existing manifolds.
