nvwiggins 85 5.0 T4R HO
#141
Yeah I've seen his and Steves blue one on Instagram. That's basically my motivation.
#142
After making the seat mounts I've since just been trying to clean it up a bit. I buffed it with fiberglass deoxidizer because it had a ton of hard water stains on it from sitting in the guys driveway I bought it from. I think it came out pretty good, at least it has some reflection in it now as opposed to when it was a chalky sand color.
#143
Looks good!
#144
After about 1.5 years of not having a front driveline I finally had one made, it uses 1310 U joints instead of the smaller ones that came stock with the front drivelines and has a pretty heavy duty slip joint. I had to re-drill the flange on the transfer case but that was a pretty easy process. After I installed it I had to take it out and make sure it was a correct length and had enough articulation in the joints. All in all I'm pretty stoked to have 4x4 again!
#146
Nice and low! Love it and this 4runner
Also I know this thing has cruise control. What about AC?
#147
#148
I see so its just open windows in the summer hah
#149
#150
Right on. With cruise control and A/C you'd be rollin
#152
Haha agreed
#154
thanks, and yeah speed holes are pretty cool, but it takes a ton of time to straighten the steel back out after the dimples distort it.
#155
Got back from King of the Hammers and mounted up an old take off set of 35" Toyos from my Tundra onto the Robby Gordon beadlocks. Front fiberglass makes the 35's look pretty small.
#156
Looks like a prerunner up front now.
I have a question about the transmission you're using. Is it the stock one out of the mustang? Not a T5 truck transmission? If so I'm curious how this thing drives with the mustang transmission having different ratios than a truck trans. I want to do a 5.3 vortec swap and am very interested in a tko600, but that is also a car trans.
#157
#158
Awesome to hear. I figured since the ratios were close it wouldn't make a big difference.
#159
While I'm gathering parts for my major suspension redo I've just been driving this thing around a bunch...still no paint, same junk shocks, mismatched springs, brackets that need to be cut off....but that can all be changed with the update. Anyways a group of us when out on a pretty mellow trail last weekend. Took a couple poser pics and video, nothing to wild.
#160
Love the dog digging the hole haha nice pics!
