Chrishf12 85 4runner Build Thread
Brought home this 85 4runner in February of 2014 with Transmission issues. Whining in 5th gear and a loud clunk from the transfer case. Here here it is fresh off the trailer. Don't mind my other 1st gen.
176k miles
Standard DLX model
Unknown lift with 33x12.50 tires
I plan to bring this thing back to DD status as a Summertime beach cruiser. Eventually my plan is to beef up the suspension and build a capable camping rig out of it.
176k miles
Standard DLX model
Had tons of fun replacing the transmission/tcase by myself without a transmission jack. Sourced a used W56 and Tcase off Craigslist.
After getting the transmission in I relocated from my parents to my own shop. Less tools but at least a dry work environment.
First things first, had to get the rear window working so the top can be removed. Turned out to be the rear wiper causing the issue. Temporary fix was to unplug the wiper in the drivers panel to get it working again.
The original brown carpet has turned to green. Entire interior was ripped out just after this picture. I haven't seen too many 1st gens with carpet covered rear panels. Was this factory or aftermarket? Also the carpet was glued to the floor pan. This was new to me. Has anyone else experienced this?
Removed the interior and found a few fun spots under the carpet.
It is not all rust, most of the brown is leftover glue from the carpet. The rust is in the normal spot around the body seam in driver floorboard. Also the rear rollbar mounts had ate through. Plan is to remove the sound deadener in the floor and Monster line from front to rear. Have new front carpet already waiting to be installed.
So the carpet being glued down created a nightmare. Carpet plugs left stuck to the floorpan everywhere. That wasn't going to work for me so out came the wire wheel. I never noticed my 3rd gen in the picture below until now. It has since moved on to new ownership.
Well I let that sit too long and had to redo the floor pan a second time due to surface rust. Decided to primer it until I was ready for bedliner. At this point I also had the body off the frame ~4" cleaning the frame and underside of the tub. Installed all new hardware and body mounts.
Some obligatory pictures of the underbelly pre-POR15. Exhaust was scrapped as it was pretty much swiss cheese.
POR15 Progress
New fuel pump for good measure. Gas tank POR15'ed undercoated and remounted.
POR15 Progress
Staff
Nice looking runner you have. I have never seen carpet on the rear panels. Since the rear was glued down, I suspect they carpet the panels. Looking forward to seeing your build.
At this point I had to get the 4runner back ready to move over to my parents to do some welding and patch work.
I had been trying to figure out why my E-Brake was not working. I finally found that the Bell crank on both rear drums were seized. Took a lot of beating but I finally got them apart to replace the cast aluminum bell crank. The oxidation expanded and cracked the cast aluminum in the process.
Fixed the leaking exhaust donut gaskets from the manifold down pipe.
Pile 'o' parts. Replaced rear brakes and brake lines to the rear.
All cleaned up. Sorry I didn't get a picture of the new shoes installed.
Pile 'o' parts. Replaced brakes all around and brake lines to the rear.
I did this exact same thing last may on my runner. My drivers side was so hung up that I could barely get the thing to move under power.
Its always a good feeling when everything is fresh and new in the rear drums.
I removed it enough to where I could weld on the floor without catching anything on fire!! Its such a pain in the butt to remove.
I am debating removing all of the sound deadener before I bed line the pan or just apply the bed liner over it.
Beginning of rust repair. Please ignore the horrible welds, welder was not feeding the wire correctly. I really wanted to go for new fiberglass bedsides but could not justify them at the time. So I patched up the rusty areas best I could. If it ever comes back to bite me then there will be some bedsides on order.
Driver side rear patching.
Passenger side had some previous patch work done to it. Final pic with mud.
Sometime during the rust repair process I made the journey over to the local exhaust shop and had new pipe put in from the downpipe back. Just went with a generic steel tube muffler to give a little tone over stock. I'm used to listening to V8's with loud exhaust, so the 4 and 6 cylinder's with loud exhaust just do not sound right to me.
This is an almost current picture after paint prep. It has been sprayed since then back to factory white. More pics to come.
Very nice man. Moving right along!
As of Sunday the paint is finally on. I think it turned out great and it was my first ever paint job. Ran into cracked bondo in the tailgate that we were unaware of. So that will have to be sanded and resprayed. Now I can move ahead with suspension and interior.
Next steps:
-Topcoat the frame and other areas to hide the overspray.
-Paint Grill and headlight surrounds and install.
-Sand and repaint tailgate and top.
-Sand and paint the wheels. Kinda digging the old wagon wheels.
-Insulate the body panels with peel-n-seal.
-Monstaliner the rear floor pan.
-Insulate and install new carpet in the passenger area.
-Still waiting on my Codura fabric to reupholster the seats.
Paint Booth Pic
Rolling it out.
Back to my dad's shop to cure for a few days.
Next steps:
Paint Booth Pic
Rolling it out.
