Build for a buddy. 2wd SAS 84/1st gen truck
Old 03-23-2014, 02:28 AM
  #41
Fossilized
Staff
dropzone's Avatar
i hope you guys have better luck with the NWOR springs than my brother in law...he ran their rear springs for 2 weeks before finding something else due to the rough ride..
this was several years ago so maybe they have changed..
i ended up with them and traded them for some random parts
Old 03-23-2014, 01:36 PM
  #42
Gizler00's Avatar
Thats not good to hear. I ordered the 2" softride springs from them. Not sure if those are the same that you guys had or not. My buddy is going to run a flat bed on the back of this thing so he can use it and load it down if he needs too. We shall see. Im hoping that they show up this week .
Old 03-23-2014, 01:38 PM
  #43
Gizler00's Avatar
Originally Posted by Terrys87
I seen somewhere you were in St Joe Mo, later this spring/summer, I should have a 92 standard cab 2wd truck that I will need to part out due to body damage. Last I looked, the frame is rock solid. If you guys want it, you can have it. I am about 3 hours further south.
Hey Terry! We got the frame from a guy in St. Joe. I would love to take a drive down and hang out for a little. Maybe I can talk the wife into taking a road trip with the kiddos!
Are you buy Columbia then?
Old 03-23-2014, 01:42 PM
  #44
Gizler00's Avatar
Update 3-23-14
Still waiting on the NWOR springs to show up.
Finally got all the from 2wd stuff cut and ground off. I let the kids do this however they felt was the best way. Seemed like it took forever but they got the job done. Mostly used a sawzall, grinder and a hand sledge to do the work.
Also ended up getting both axles off the frame and sent the frame outside so we have a little more room.
I had them using the Hotsy to clean up the axles and get all the nasty mudd off of them. I think that we are going to try and paint them tomorrow or sometime this week. We might as well make them look nice while them are out.
Old 03-23-2014, 04:47 PM
  #45
kornhuskerwizard's Avatar
Gotta love the Hotsy
Old 03-25-2014, 11:46 AM
  #46
Staff
Terrys87's Avatar
I am all the way in the very far southwest corner of Missouri. Oklahoma and Arkansas make up tow of the county lines. I go to the quad cities up in Iowa and Illinois every once in awhile.
I have never noticed that bar on the drivers side and going to the front of the frame, by the motor mount on a two wheel drive before. If my old two wheel drive had it, I really do need to get my eyes checked.
Old 03-25-2014, 03:52 PM
  #47
Gizler00's Avatar
They are here!!
Old 03-26-2014, 05:18 AM
  #48
Gizler00's Avatar
Things are finally coming together. The NWOR springs and u-bolts showed up yesterday and were waiting at my front door when I got home from work!
Now that the axles are out, the kids have been cleaning them up and trying to get things in order to start installing them.
Front axle is off and getting ready to be cleaned up.
Rear axle has been wire wheeled and painted with some universal black paint that we had. Something just to make it look nicer while it can.
Hopefully this week we can start making the shackles and get everything ready to bolt up next week. I am going to have to purchase the Pins from NWOR to fix the springs to the frame. I waited to do this until I was sure that was the route we were going to take.
Old 03-26-2014, 11:56 AM
  #49
rustED's Avatar
Man, you and your students are making quick work of the frame and chassis! Can't wait to see the new springs installed and it back on all fours!
Old 03-26-2014, 01:15 PM
  #50
Nice work!!Hope everythings going well and im happy your springs showed up!!
Old 03-27-2014, 05:32 AM
  #51
Gizler00's Avatar
Thanks man. We are finally starting to make some good progress with everything that we have in the shop. We are going to start making shackles today.
Old 03-27-2014, 05:34 AM
  #52
Gizler00's Avatar
Me too buddy!! We are going to try and tackle making the shackles today. You said the ones you have are 3/8"? I have to see how thick or thin the metal is that I have.
Old 03-27-2014, 05:39 AM
  #53
Gizler00's Avatar
Update 3-26-14
We were able to get the old front leafs off without damaging the front shackles. We are not going to use them, But I always like to try and remove things properly. You never know when you might actually need them or end up using it as a reference.
A couple of my really good solid workers hammered the rest of this out and got the leaf packs totally off of the frame. We are going to start pressing out the OEM shackles today.
On the agenda for today is to start making the shackles and try to order the bolts/pins for the springs from NWOR.
I am also going to take some measurements from the tubes on the 84 frame since we are going to try and make those as well.
Will report back later.
Old 03-27-2014, 07:25 AM
  #54
Staff
kawazx636's Avatar
What you are doing for these kids is great! I wish we had shop classes like this in my area growing up.
Just to let you know, TrailGear makes factory length greaseable shackles
Old 03-27-2014, 05:13 PM
  #55
Ill give kelvin measurements on the tubes.
Old 03-28-2014, 05:23 AM
  #56
Gizler00's Avatar
Thanks for the kind words. I also wish I could do this growing up in HS.
Thanks for the tip on the shackles.
I see that you live in Salisbury, MD. If its the same Salisbury MD that was not far from Grantsville, MD or Mt. Davis, PA, I grew up in those parts. My parents had a place right on the border of Forbes state forest across the road from MT. davis, PA.
Old 03-28-2014, 05:25 AM
  #57
Gizler00's Avatar
Thank you for doing that. I am going to order the Frame Jigs today. I also need to order the pins from NWOR Need 12 of them at 15$ a piece. Then the axles will be able to mount up to the frame.
Old 03-28-2014, 05:29 AM
  #58
Gizler00's Avatar
Update 3-28-14
Still going at it hard over here. I had the kids cut out some steel for the shackles from a piece of 1/4 that I had sitting around.
Heres after they were finished cutting. They were able to get out 8 of them before the day was out.
Thata about all we were able to get done yesterday since we are going through Ncarmen91's truck in the shop as well. But we should have his finished up by the end of the day today.
Old 04-01-2014, 05:11 AM
  #59
Gizler00's Avatar
Update 4-1-14
I just placed and order with Skys offroad for the Frame tubes with bushings and a jig kit. Found them to me the best price overall.
I tried ordering the pins and bolts from NWOR but they are sold out at the moment. So I am going to head to the hardware store to pickup something equivalent in the meantime so I can hang springs.
Old 04-01-2014, 05:31 AM
  #60
rattlewagon's Avatar
Looks good! What are you using for a front hanger?
Quick Reply: Build for a buddy. 2wd SAS 84/1st gen truck
