775Toy's 84 X-cab build Thread
Old 01-09-2012, 02:17 PM
  #41
irab88's Avatar
Originally Posted by 775Toy
Stock 63" chevys. Gave it about 4" lift with 6" shackles. Got some wagoneer 44044 ranchos to go up front to give me around 5" and level it out.
sweet, thanks.
love the transformation. keep it up!
Old 01-09-2012, 06:14 PM
  #42
775Toy's Avatar
Wire wheeled the rear frame on the lunch break, paint and cut the stock spring mounts tomorrow. I picked up these sony xplods for the rear xcab speakers.
Old 01-11-2012, 06:52 PM
  #43
775Toy's Avatar
Got the rear all cleaned up and painted , the gas tank is dropped off to be cleaned out. Putting the bed back on tomorrow and start the front suspension and high steer soon.
Old 01-11-2012, 08:03 PM
  #44
jessamiah's Avatar
you move quickly. im gonna watch this one. love that steering wheel
Old 01-11-2012, 08:57 PM
  #45
streetlancer's Avatar
Nice, very nice! You make quick progress. You'll let us know how those chevies ride won't you? I'll most likely be using those too.
Trail-gear hangers you said? I cant seem to find them in their website.
How did you know where to mount the hangers? Did you use a jig to hold in place or did you just eyeball it? I'm concerned about the placement, for example: how did you manage to get them parallel along the bottom of the frame? If they were off does it eat the tires because off bad alignment?
Old 01-11-2012, 09:06 PM
  #46
RMP8080's Avatar
Every good, wish mine move the fast, can't wait to see the finished Toyota.
Old 01-12-2012, 09:35 AM
  #47
775Toy's Avatar
I bought the hangers from a local guy who bought them from trail gear. I'm pretty sure they are on the website under suspension or something.
I didn't use a jig , the front hangers are wider than the frame so I basically centered them , then went 11" forward from center of bolt hole from the old hanger to the center of new. Then used a big c clamp to hold them down while I placed the rear shackle mount where I wanted ,Keep in mind like the pics show I have all hangers/shackles/leafs ect bolted up and attached to the diff. Made sure I was in line with the front hanger, then figured out my shackle angle , which I set at 35* which was about 3"back center to center from old shackle mounts. Then tacked the rear shackle mounts , double checked my front hanger measurements and tacked those. Then measured from rear of front hanger to the back of frame on both sides to make sure it was all straight and finished the welds.
Here's a quick idea of how I Got 11" center to center on the front. Keep in mind that every build is gonna be a lil different depending on where you want your rear wheels to sit in the wheel well , I wanted them to be almost stock or a lil forward cause I will be stretching my front axel out a few inches and dont want a crazy long wheel base so I did stock or a 1/2 in or so forward on the rear. I will need to trim wheel wells anyways so it won't be an issue. Some like to set the front hangers less than 11" so it puts the rear axel back in the well to stretch base.
Old 01-14-2012, 06:54 PM
  #48
775Toy's Avatar
Not a real productive day. Walked around the shop looking for tools I just had ! Nothing lined up , ect ect. I did finish my front shackles , and get started on my front suspension. I didn't bother cleaning the frame or differential , gonna rebuild the front diff and add armor and a truss so it will get cleaned up them and brackets cut off I don't need. The frame will get cleaned up when I get my ifs box mounted.
Tore out
Rancho 44044s vs stock
44044s with sky's ubolt flip and homemade shackles mounted up ready to go in.
So I had a brain fart when I got my new grade 8 hardware , did compensate for the Toyotas off set shackles in front. So my bolts weren't long enough and didn't have a spacer for the gap it creates. So to get it on its own weight and get it out of the shop I had to improvise. Old ubolt cut in half lol. Will hold it in place till I get correct bolts and spacers.
Hung
Couple of stance shots
It's pretty tall , about 6" with the 44044s and shackles. It's on stock wheels and tires so it's gonna be a beast on 35s. I might be bringing it down some in the future .
Old 01-14-2012, 07:33 PM
  #49
TinMan's Avatar
Hey man for the 63" springs, what bushings did you use? Stock or some poly one? And where did you get them?
Looking good man.
Old 01-14-2012, 08:45 PM
  #50
westjohns yota's Avatar
wow what a major improvement, what size tires are you gonna be running? regear? does it even run yet lol???
Old 01-14-2012, 09:22 PM
  #51
775Toy's Avatar
Looking good man.
When I got the 63s they were aftermarket oem replacements that were only a year old . So I just ran the bushings they came with since they were practically new. But summit does sell energy suspension bushing kits for 88-98 chevy rear leafs which I will do eventually.
Old 01-14-2012, 09:56 PM
  #52
775Toy's Avatar
35s with open diffs and stock 4:10s and possibly weld or spool the rear this summer since I will only be wheeling in the local hills and trails and won't see much highway use. Next winter I'd like to regear to 5.29s / lock front and rear and run a set of 30 spline longs with 37s. Got another kid coming soon so I have to set realistic goals. The truck will only run with gas down the carb due to bad fuel pump . It sat many years so the tank got pulled out to be professionally cleaned , I ordered a carb rebuild kit a new pump.
Old 01-18-2012, 12:53 PM
  #53
775Toy's Avatar
So a week or so ago I got a ifs power steering box thats already tapped for hydro assist to use with my high steer kit, I picked it up for a case of keystone ! I was told it just needs a new o ring on the worm drive cap. So I pulled the worm drive out like a newb and dropped all the little ball bearings in the bott of the piston. So I tore the rest of the pump apart to put the bearings back in. I only counted 43 bearings , but read 43 / 44 and 45 online? So I tried 43 that I had , it would jam up after a turn or 2. So I tried 44 with same results , 45 seemed to work. Got it all back together and made a home depot run to pick up some pipe plugs to plug off the hydro assist holes for now.
Old 01-18-2012, 05:18 PM
  #54
TinMan's Avatar
Looks good man, I need to replace the worm drive seal on mine. Supposedly when I bought it, it was a marlin rebuild, but the front seal is leaking t the steering shaft. I may go a head and tap it for hydro steering later on.
Old 01-18-2012, 07:11 PM
  #55
775Toy's Avatar
Might as well tap when it's all apart. Even if you never use them the option is always there.
Old 01-19-2012, 05:26 PM
  #56
775Toy's Avatar
It's been pretty cold and windy in Reno the last few days , I havnt felt like going outside and working on the truck on my lunch breaks. So I've been finding things to do inside like putting the ifs box together and today I got the steering shaft out and got it apart. Don't believe what you read online that you can just drill the 2 Plastic pins out! I drilled them out and gave it quite a few smacks with a big rubber mallet and no budge. So I turned to the lil Coleman propane torch. Heat it up by the holes for a few minutes and the more plastic started flowing out the holes , once I seen no more plastic coming out I gave it a good couple smacks with the mallet and wala came apart. Used a wire wheel and file to Clean the rest of the melted plastic off the shaft ends. Once I get the box mounted I'll figure the length I need to stretch it.
Old 01-21-2012, 01:49 PM
  #57
Imtight2001's Avatar
Cold and windy is it. You guys just had that big fire rollin' up from Washoe too :3 Still a little jealous on the keystone trade for the steering box.
Does the engine have any problems at all?
Old 01-22-2012, 03:21 PM
  #58
Neren's Avatar
Truck looks great compared to how it started
Old 01-23-2012, 07:14 PM
  #59
775Toy's Avatar
Yup lil fire on the outskirts of Reno. Out now, but burned like 29 houses and lots of acres. The engine should be fine , ran it for a minute pouring gas down the carb , it sounded fairly healthy. The fuel pump is shot , so a new fuel pump and carb rebuild kit is coming in the near future after I get my fuel tank back.
Neren- thanks , you got a build thread?
Old 01-24-2012, 04:29 PM
  #60
775Toy's Avatar
Got the stock steering box out , and did a little trimming to get ready to mount the ifs box
Quick Reply: 775Toy's 84 X-cab build Thread
