1984' 1uz 5speed 4Runner fiberglass build up
Old 11-18-2015, 05:01 AM
1uzRunner's Avatar
Well been slow going but a couple rain days have opened up some work time!
Got the doors bonded, and the tailgate!
Got the shop cleaned and reorganized.
Old 11-18-2015, 05:03 AM
1uzRunner's Avatar
Doors and tailgate ready for trim and paint!
Had some help with the windshield, .030 welding wire works great for cutting it out! Thanks Deann and Aaron! Lots of rust repair in the windshield frame.
Also, got all the wiring out of the truck, stripped the insulation from the firewall so it may be repaired. Lot worse shape than I had thought!!
Old 11-23-2015, 04:38 PM
Gizler00's Avatar
Dude.........This is Awesome!! Looking badass so far!!
I love that you used Por15 on the inner quarters.
Old 11-23-2015, 06:00 PM
Boomtacoma01's Avatar
Great start so far
Old 11-23-2015, 07:13 PM
  #25
1uzRunner's Avatar
Thinkin I shoulda bagged this stuff!
The wheelhouses are a little wider so I will be starting that next. I have the steel, just need the time.
Then my body mounts and 6 quarts of redline shockproof gear oil showed up!!
Behold the wall of Toyota parts forming in my shop!
New: Headlight buckets, front marker lights, turn signals, tail lights, door locks, and body mounts. Also new 23 spline marlin input and gasket kit.
Old 11-23-2015, 07:25 PM
  #26
Gizler00's Avatar
Very nice man. Are you going to extend the inner fenderwells out then bond them to the Fiberglass?
Just curious as I have never used the Fiberglass panels on any Toyota's.
Where did you get the Fiberglass panels through?
Old 11-23-2015, 07:58 PM
  #27
1uzRunner's Avatar
In the rear yes, not sure yet in front.
Fiberglass was built by Precision 4x4 out of Canada!
Awesome stuff!
More soon!
Old 11-24-2015, 12:27 PM
  #28
rustED's Avatar
Nice work, it's really starting to come along! Just curious, how much additional clearance do the High Clearance fenders and quarters panels provide over the stock ones?
Old 11-30-2015, 05:16 PM
  #29
1uzRunner's Avatar
Old 12-06-2015, 07:29 PM
  #30
yoterr's Avatar
Nice work man, I can't wait to motor swap mine, only going to a 7m tho lol hopefully the stock stuff can handle it
Old 12-09-2015, 09:40 AM
  #31
Back to the Future's Avatar
Gonna be one helluva beast when you get it done!
Old 12-09-2015, 10:02 AM
  #32
Old 12-12-2015, 05:56 AM
  #33
1uzRunner's Avatar
So, body is off and flipped on its side. The sandblaster I have is gravity fed so it had to be flipped. Hooked the pressure washer up to the 40 gallon water heater and blasted everything again after the sand blast! Then everything was treated with rust kill, and rinsed again! After a few hours in the shop drying, Por-15 was applied to the entire bottom of the body. Two coats, an entire quart!
When I was welding the patch panels in, my co2/argon ran out so I left an area around the needed repairs uncoated for future repair.
Off to go get bottles filled, and pick up more supplies! Sould be a great weekend to get more done!!
Here are a few pics of recent work done.
Body being pressure washed:
Here it the body all blasted and drying:
Make sure to give yourself plenty of time for applying por-15, I started at 8:30 and didn't finish the second coat till after midnight!
Old 12-12-2015, 06:03 AM
  #34
1uzRunner's Avatar
Welding kick panels and starting on pressure washing and blasting the frame today. Thinking of going with grey for the frame as well with the por-15.
Last few years I been digin light colored parts for under the truck. Not only can you see better when working on it, but its also easier to clean when it gets muddy!
Old 12-12-2015, 07:43 PM
  #35
Gizler00's Avatar
Looking great!! Love the gray por15!!
Old 12-13-2015, 09:50 AM
  #36
1uzRunner's Avatar
Friend stopped by and gave me a hand with things, took some evedince photos. lol
Anyway, heres a few shots of the rust repair this weekend.
Old 12-13-2015, 09:59 AM
  #37
Gizler00's Avatar
Very nice. You are really taking the extra steps to fix this thing up right.
Old 12-14-2015, 09:42 PM
  #38
1uzRunner's Avatar
Things been taking too long so I just dove in after work, here's the pics.
Here is the carnage so far...
Used the metal from the original door skins...
Yeah I know, welds look like ˟˟˟˟, that ˟˟˟˟s thin yo!
Old 12-15-2015, 02:01 AM
  #39
bootscootboogie's Avatar
What do you have your welder set to? I haven't welded any of this thin metal so I'm curious. It's looking good. I think the trucks gonna look mean.
Old 12-15-2015, 03:31 AM
  #40
1uzRunner's Avatar
The welder has .030 wire and I had to run it on 120v input at the lowest setting or it would just burn through. On 120v it runs 20v, 220v runs 23.5v. Not sure what the minimum amperage is but the open circuit voltage is lower on 120v as well.
Quick Reply: 1984' 1uz 5speed 4Runner fiberglass build up
