southernZ's 1980 Pickup Build-Up Thread
Old 10-27-2011, 06:30 PM
  #61
Staff
Terrys87's Avatar
Wishing the best on your parts getting in today. Just checking in. Great job.
Old 10-29-2011, 09:24 PM
  #62
igotit's Avatar
nice progress.....maybe in 4-6 mths ill be doing the same to my 81 axels.
i have 33 swampers on my stock 82 4:10 gears,its a slow truck on the road,but a monster in low range.
with 33's and 4:88's should get the truck on par with a stock 4:10 and 29's
Old 10-31-2011, 08:14 AM
  #63
southernZ's Avatar
Well all the 3rd parts came in (thanks Wab), now im waiting on the front lift springs. hopefully they will be in one day this week. I had to sent the stabilizer back to 4wheelparts....They sent the wrong one (had eyes and bushings on both ends)..
Old 10-31-2011, 08:17 AM
  #64
southernZ's Avatar
It would be great if someone had the correct part no. for a Rancho 5000 steering stabilizer? The one they sent was part no. rs5401.....Or are there any suggestions to a good quality stabilizer? Thoughts/comments are appreciated!
Old 10-31-2011, 03:30 PM
  #65
Yopar's Avatar
I'd go Old Man Emu, they are great quality. part #SD21
Old 11-02-2011, 06:15 PM
  #66
southernZ's Avatar
Lift springs are in.... thanks KillerB! Now i just have to get the bearings installed in the front 3rd ad get a steering stabilizer....Then she can get put back together.
Old 11-03-2011, 02:07 PM
  #67
Staff
Terrys87's Avatar
Sounds like things are going goood for you. Hope all goes on well for you.
Old 11-07-2011, 03:43 PM
  #68
southernZ's Avatar
Got a little update....I got the axle back together and under the truck. I am having problem with the wheel bearing preload set. Passenger side is a little tighter than the drivers side. Also the one hub i got back on (passenger) is not engaging. I called it quits for today and will start back up when i get back home. The 3" superlift springs picked the front up ALOT. Comparing to the wore out stock springs, the the 3" springs raised the front of the truck almost 5"! Did not get the drive shaft, shocks, stabilizer, drag link hooked back up yet. I still have to order a dropped drag link, new u-bolts and the steering stabilizer. Then i am going to start working on the rear axle/suspension.
Old 11-10-2011, 08:29 AM
  #69
1986yota4x4's Avatar
thing looks sick!
Old 11-10-2011, 05:19 PM
  #70
southernZ's Avatar
Thanks man....I like the way it turned out. Now im just ready to drive it!...lol
Old 11-11-2011, 01:14 AM
  #71
Staff
Terrys87's Avatar
Truck is coming along. Looking great. Hang in there, you will be driving it soon.lol
Old 11-11-2011, 07:19 PM
  #72
clark-camp's Avatar
You figure out the vacuum hose situation? I can go look on my truck and at my hose diagram and tell you where the hoses are supposed to go and what they do.
Old 11-11-2011, 08:45 PM
  #73
Fossilized
Staff
dropzone's Avatar
didn't see a post about this but if you need it, here are pics out of the my 81 FSM-might help you out:
http://s119.photobucket.com/albums/o...acuum%20lines/
Old 11-12-2011, 05:26 PM
  #74
southernZ's Avatar
Thanks a bunch guys!..... I wouldent call my vacuum problem fixed, but it runs decent. I will know more once I can get it on the road and see how it acts through various rpm's. I will be ripping out the egr and all that emissions crap eventually. I downloaded a FSM for the first gen pickups and there is all sorts of info for the 22r but nothing for my 20r... no diagrams, valve clearances or anything....pretty much a let down....thanks for the diagram ocdropzone, that will come in handy soon.
Old 11-12-2011, 07:45 PM
  #75
4x4YOTA's Avatar
where did you get the FSM ive been looking everywhere for one for my 81
Old 11-12-2011, 08:05 PM
  #76
leapinlizard's Avatar
i have a 1980 pick up with the 438 and i run 37's trucks not very fast but the 22r does just fine with those so you should be ok with 33's or 35's im also looking for new parts for my rear diff there is nothing in central ny
Old 11-13-2011, 06:17 PM
  #77
southernZ's Avatar
4x4yota, man my wife is the one that downloaded it for me..... ill see if she remembers where the web site is though. I think she just goggled it though?
Old 11-29-2011, 02:57 PM
  #78
southernZ's Avatar
Ok, time for a little update. I got everything back on the truck. I took it for a test drive and could not get over 25 mph. ALOT of death wobble. I know it needs to be aligned and i still need to get a steering stabilizer and hook up the sway bar. Also there is a terrible amount of slop in my trans shifter, that needs to be fixed ASAP. Ill get some pics up tomorrow.
Old 11-30-2011, 01:29 AM
  #79
Staff
Terrys87's Avatar
Atleast it is movable now. So it is some progress. That is a big step. Hopefully the tranny just needs the bushing. The wobble shouldnt be to bad. Congratulations on the progress so far.
Old 12-01-2011, 06:26 AM
  #80
southernZ's Avatar
I figured out what was making the wobble, it helps when all your lug nuts are tight!.......So i went and got a cheap stabilizer for now. i got it up to 45 mph and all was good. Im gonna try to put a few miles on her today. The only thing id with the lift i was unable to get the torque arm hooked back up (i think that is what its called? The arm that bolts on the drivers side of the axle?) Any tips/suggestions for this? I also have to get some longer sway bar links.
Quick Reply: southernZ's 1980 Pickup Build-Up Thread
