Duckmaster88's 1980 4x4 build up
new carpets on the way
I think it will all match up
color of the inside
color of the seat
color of carpet
just waiting on the stuff to come in so I can get it installed the seat is being recovered in the tan vinyl, the floors will be the darker brown and the pannels will be tan. i think it will all tie in nicely
color of the inside
color of the seat
color of carpet
as of right now its just a daily driver and small wheeling im more intrested in restoring it than tearing it up.. i might find another motor to put in my camo 82 to play with later on
well im finally home to work on the yeller yota so far ive replaced the u-joints,rear shocks, had a bench seat from a 2wd with console recoverd in tan vinyl, ive cut out all the cancer(which was about 3/4 of the passanger side) in the passanger floor board and welded new sheet metal in i will be posting pics tomorrow check in if you want to see im moving at a pretty rapid pace!
#27
Good to see someone keeping one of the "good ones" alive (79-85) Mine is an 80 and I will be posting about it soon. I'm new to the site but old to the Toyota.
#28
Sorry I havent been on I have a lot of pics to post but I haven't had the time but as for a update the floor boards are cancer free and patched the carpet went in pretty good but I cut a few extra holes for the gas pedal and it's a little fluffed out around the hump but for Pre molded carpet it's pretty good had a 80 Toyota 2wd seat recovered in tan vinyl and put it in also got a wood grain dash from 17toyota and put a radio in and a set of 6 1/2in speakers behind the seat and a 6 1/2 mid sub under each seat also had to tap into the cig lighter to power the radio since mine didn't come with prewire for a radio ad that completes my inside so far, I put a little over 200miles on it the first two days I had it running and the clutch came apart from sitting so long fixed that and got some new tires all in the same day
Next thing is to get the gasket around the windshield replaced and then on to putting my other bed off my parts 82 I'll be posting more pics around Monday when I get back from visiting family thanks for keeping up and all the help and advice!
#29
#31
Hey, Duck.
If you want it, I have a spare bezel for the gauges that mount in front of the heater box. Blasted vultures at PnP snagged the gauges, but it's a good-conditioned box you can put aftermarket gauges into.
If it sounds good to you, it can be yours for the price of shipping.
#32
Hey, Duck.
#34
Attachment 90300
New bumper i finally had a chance to put it on looks pretty decent can't wait to put the other bed on so it won't look so funny lol
Attachment 90301
Attachment 90301
#35
Ok just a question how hard would it be to swap my 20r for a 22r I'm wanting a little more power I have a 22r that needs to be rebuilt I think it has some nocking I'm hopping to go through it on my spare time and see if I can't figure out what's knocking and also is swaping my 20r to the 22r worth the time will it add any noticiable amount of power/speed ?
#37
Right now the 20r is in my truck so I'm debating on weather or not I should take the 22r out of my other truck have it rebuilt and put it in my dd ? I'm running 31s with 4.75 gears I believe
#38
Hey Duckmaster88, I did just that. I put a 22R in my 80 and I had noticeable improvement in power and in economy. Maybe my 20R was a real dog. The 22R is still not a rocket. Not at all. It took me a long time to convert all the wires and computer because it was all new to me. The bolts lined up with the holes real well. I have heard of using the 20R head on the 22R engine because of bigger valves. I never checked it out and don't know if it's true. However, if you are rebuilding it, do at least some improvements in the performance dept.
#39
Well so far she runs good and I'm about done with the inside of it just want to mount the volt and oil gauge bezel in an buy some speaker pods. For mounting my speakers and replace the windshield gasket and I should be able to move on to putting the other bed on it and save for the front fenders lol money is starting to slow down but it's been well worth it I love the little truck and surprisingly most people I know have liked it they call it vintage I call it a solid dependable truck but every body agrees its a sick old truck with a lot of potential ill try to get some pics up of the patch job I did on the floor pans soon
#40
Few minor updates I finally got the timing close to perfect but still needs a little adjustment, also when I first got the truck it took me forever to get to 55mph and it was bottomed out pedal to the floor did some digging around found out I had to much slack in my throttle cable took out the slack and now I can hit 55 in about 2 football fields also did some moving stuff around and loaded it down with a 10ft sea container, 2 onan military generators and a road construction light tower needless to say it was loaded to the max!
I had some time to take the bed off the other truck and look at it it looks like its in great shape except for one place about the size of your hand has bondo on it but its where a dent was so as far as rust it's pretty clean!
