Sign in using an external account
| Pre 84 Trucks (Build-Up Section) Post your build-ups here |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
541SR5's 1981 Pickup Build-Up Thread
#2 (permalink) |
Personal
Sales Rating: (0)
nice truck, whats the 541 in your name stand for?
#3 (permalink) |
Personal
Sales Rating: (0)
nice truck more updates and pics lol
__________________
84 toy 4x4 5speed 529s 6 inch lift flat bed new 35 kevlars 6500 miles on 22r bored 40 over 268 torquer cam from eb port and polished head bigger valves etc headmen comp header 40 series on 2.5 pipe way to much to list and motor is balanced for them high rpms all day |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
#6 (permalink) |
Personal
Sales Rating: (2)
-go to a picture hosting site, such as photobucket.com, and create an account (free)
-upload your pictures -click on the "[img]" code, and the word "copied" should appear -in your post here, paste the code, which should look like this: [img]http://photobucket.com/irab88/albums/truck1.jpg[/lmg] -when you click "post", you'll see the image
__________________
--Ian I'm not going slow; I'm just enjoying the trail... 93 PickUp DLX, 22RE-C, 4x4 Build Thread: the Red Rover |Last »| 135 (my trailer build)R151F, 2.28 & 4.7 ╠╬╣ 24R LL4 RADesigns Shifters ║║║ HH2 (my boat build) |
#7 (permalink) |
Personal
Sales Rating: (0)
lol 541 is my areacode
#8 (permalink) | |
Fossilizing
Personal
Sales Rating: (3)
Staff
always like to see another first Gen build, especially an 81
![]() Quote:
1) the transfer case doesn't get properly lubed with the rear output shaft spinning 2) you run the risk of it going into gear. I was too lazy to pull the rear shaft (it was raining hard and I was tired) tranmission or T/C slipped into gear and I trashed a transmission and one of my dual cases....
__________________
~robb '81 Toyota Trekker The B4Runner Mini FAQ/Ideas PNW wheeler group: Gitout.Com |
#9 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Thanks! I'll keep these tips in mind just in case I ever have to pull it. |
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
The Work Begins...
I haven't posted any updates in awhile so now that's hunting season is over it's time to get my thread up to speed.
The first thing I did, after making sure the truck wasn't too far gone for a rebuild, was remove the bed. Don't ask me why I started on the business end first, I guess because it would let me to save up some cash before I started on the front. ![]() ![]() ![]() The frame wasn't in that bad of shape, just some expected surface rust. I was also able to see what all needed to be replaced which looked like everything...
#11 (permalink) |
Personal
Sales Rating: (0)
Nice little truck man....
__________________
1980 Toyota SB 4x4--N78 Buckshots, Warn M6000 1983 Toyota LB 4x4--parts truck 2011 GMC Z71--2.5" Leveling Kit, 33" M/T's |
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks, it's been a fun truck work on for the most part (there's been a few times where we disagreed, but I usually came out on top). I think got really lucky because the truck was all original (minus the wheels and rollbar) and it was stored in a garage the whole time. Very little bad rust, mostly surface rust.
#13 (permalink) |
Personal
Sales Rating: (0)
[OP]
Rear POR-15
Once I got the bed off, I started by draining all the gas out of the gas tank...lucky for me, it was 3/4 full
![]() While looking up places to take the tank to get it fixed, I came across some stuff called POR-15. The more I read, the more I liked what I heard about it's rust prevention and how you could paint over rust. Even better was that the shop and was dropping the tank off to have fixed also sold POR-15, so I bought a starter kit to try out. I have a painting background, so I was a little unsure of how the paint would work by just brushing it on. ![]() Much to my surprise, it layed down really easy and once it dried I had zero brush strokes. I just followed the directions..knocked down all the loose scaley rust with a wire brush and sandpaper then hit it with marine clean and metal prep. After that I put on 1 coat of silver (to fill in any pits in the metal), then put on 2 coats of the gloss black, and finished it with 2 coats of the Chassis Coat Black (sorry I didn't take any pictures between coats). ![]() While I had the shocks, brake lines, emergency brake cable and other parts out of the way, I decided to go ahead and paint the rear axle and springs with POR-15 also. ![]() Those turned out just as nice as the frame and the rearend went back under the truck. During this time I also ordered new shocks for the rear...Bilstein HDs. After about a week, I got a call my gas tank was ready. I had it "Renewed" as they called it, which is basically fixing any holes or leaks and then spraying the tank inside and out with a rubberized coating. That weekend I put the new shocks on and put the gas tank back in. I left out that I replaced all the rubber hoses and clamps going to the gas tank, as well as replaced the sending unit and fuel filter. I also cleaned up, painted, or replaced all the hardware holding the rear axle to the springs. A shot of it looking all nice and new ![]()
#14 (permalink) |
Personal
Sales Rating: (0)
stupid question but did you put POR15 on the tank too or is that some sort of herculiner?
#15 (permalink) |
Personal
Sales Rating: (0)
[OP]
I took the tank to Don Hart radiator (do a google search and his website will come up). They have some kind of process called Renu where they take a gas tank, fix any holes or leaks then they put some kind of rubberized coating on it inside and out (that's what you see). If I was to guess what that coating is, it might be that Lizard Skin undercoating because they are a dealer for that too. And they might have POR-15'd it before they put that coating on. I wasn't smart enough to ask them when I had my tank done, I just saw a tank after it was done and I was sold, plus it has a lifetime warranty.
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
#17 (permalink) |
Personal
Sales Rating: (0)
Looks good, love to get a 1st gen
__________________
1986 Yota Pickup 4x4-4" shackle lift rear, 2.5" Torision lift front running 31x10.5R15. Chrome Rollbar and side steps. Acell 7mm Plug wires, K&N Air Filter, modified exhaust.In beginning stages of rebuild after accidendt Rebuild Thread dsal_86Yota build/rebuild 1986 Yota 4x4 Pickup 1986 4 Runner*SOLD* |
#18 (permalink) |
Personal
Sales Rating: (0)
[OP]
#19 (permalink) |
Personal
Sales Rating: (0)
[OP]
The Engine
Once a had the rear painted, gas tank in, and new rubber fuel lines replaced, I decided to turn my attention to the engine.
![]() ![]() First I looked at rebuilding the engine myself, because it really didn't look that bad. However, before I got too deep into it, I went to a local engine shop just for grins to see how much they would charge. To my surprise, they weren't that much more than what it was going to cost me to rebuild it, if I had the machine work done, buy the rebuild kit, rent (or buy) the tools I would need (engine hoist, stand, etc.). Plus I would get 3yr/36,000 miles warranty and a lot less headaches ![]() Before I took it to the shop, I also decided to take off a parts exterior parts too...bumper, grill, headlights, mirrors, radiator, and a few other misc. things. ![]() ![]() On the way to the engine shop... ![]() A couple weeks later I got a call that my engine was a "rust bucket" and might be smarter if I put a new long block in it. I happened to be off of work that day, so I drove over to the engine shop to take a look and discuss. After taking a look at my engine torn apart, I had to agree that it looked pretty bad. It could be saved, but it would cost more than putting a new one in . So I decided to put the new one in.Engine gone... ![]() ![]() ![]() Couple weeks later, I got a call that the truck was ready to come get and it was running! I was super excited, because I hadn't heard it running since the late 90s (and I was glad nothing was wrong with the electrical). New engine ![]() I plan on doing a few things to detail the engine before it makes it debute, but for now, it'll work. Last edited by 541SR5; 02-05-2012 at 04:46 AM. |
| Tags |
| 15, 1981, 4x4, black, chassis, coat, front, kit, leaf, painted, pickup, pics, por, spring, sr5, starter, suspension, toyota |
