2010+ 4Runner 5th gen 4Runners
Pic Request - Rear Parking Brake Cable Routing
Old 09-14-2016, 02:59 PM
ewong's Avatar
I am thinking of getting the Front Range Off Road - DRotor upgrade kit (along with a full floater axle)
The kit mounts a current iteration 4Runner rear brake set up on an older generation Toyota axle housing.
So it essentially mounts a 4Runner rear disc brake AND the integral "drum" parking brake on to a FULL FLOATER modified early generation Toyota axle.
What is NOT clear from the pictures, is how the parking brake cable is routed on the current 4Runner.
http://frontrangeoffroadfab.com/drot...e-upgrade-kit/
I would like someone to take a pic of their stock rear axle, showing how the parking brake cable is routed..
I looked under an FJ Cruiser, but could not see a cable mounted "behind" the axle.
The reason for the curiosity, is that I also plan to convert the axle to a spring under configuration, and I want to know if I am going to create interference with the "bell crank" if I re locate the spring perch.
Shots similar to these (of my truck)
RAD4Runner
04-24-2018 08:20 AM
Barnes 4wd
Vendor Advertising
16
11-17-2016 10:22 AM
Barnes 4wd
Vendor Advertising
14
11-15-2016 02:08 PM
az1320
06-20-2016 07:07 PM
Quick Reply: Pic Request - Rear Parking Brake Cable Routing
