2010 4runner question
#82
Car and Driver article on the 2010 4Runner, including some new spy photos. C&D claims the 4.6l V8 will indeed be available (which of course the Toyota Canada .pdf disputes). I can forgive Toyota for the pole antenna if we get the V8.
http://www.caranddriver.com/news/spi..._4runner-spied
#83
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
#84
Wow, so much for C&D being creditable, they retracted their story because someone sent them the .pdf going around.
Guess journalists don't do research anymore.
http://blog.caranddriver.com/2010-to...linder-option/
#85
#87
FWIW, I was told the new 2.7L 4 cyl. will only be available in small numbers, and then only on the lighter 4X2. It was done to pump up the EPA #'s and Toyota expects few actual sales. Regions are only ordering enough for one per dealer initially to judge market reaction, so if anyone actually wants one in a certain color, they'll have to hunt.
#88
considering the first three gens all offered a 4 cylinder engine, its not such a bad idea. look on this site, a lot of people love the 4 cylinder. Just because it doesn't go fast doesn't mean its pointless. good gas mileage ring a bell?
Besides, when you use low range, if you aren't turning huge tires, it doesn't matter if its 4 cylinders or 8. Considering the 4 cylinder that is going to be offered is almost the same horsepower as the V6 offered in the third gen and well over the V6 offered in the first and second gens, its really hard to justify calling pointless haha.
The 4Runner's true heritage had nothing to do with speed and power. The fact that the 4th gen sold out to that Americanization crap is a shame (think GM and Chrysler, what exactly is it they did with all their vehicles that rendered them a failure??). I for one am very glad to see the return of a 4 cylinder. There are plenty of big, bloated, and over powered vehicles out there. Why not go back to its roots? CAFE standards are looming anyways, and if you want to see the 4Runner survive into the future, this is the only way it can happen.
Not to mention the price will be lowered, which makes it easier to get more people into a 4Runner. There are many of us who would want to get into a 4 door Toyota SUV with four doors and a live axle in the rear, a frame under foot, and not have to deal with shopping mall'd out pavement pounders. Sure, the 4Runner has a little ways to go yet to satisfy a lot of our needs, but this sure is a step in the right direction.
Thats my argument for the 4 cylinder lol
#89
2) The 4-cylinder simply isn't going to get very good gas mileage. It will have the same poor aerodynamics as the V6. The overburdened 4-cylinder will be working so hard that it won't save you much gas in regular driving.
There are two ways Toyota could get significantly better mileage out of the 5th gen 4Runner: a) redesign significantly smaller and lighter, and/or b) equip it with a turbo-diesel engine. But Toyota isn't going to do either.
The 4-cylinder is simply going to be ineffective greenwash.
#90
1) The first three generations were much lighter than the gen 4, and it appears that the gen 5 size and weight will be similar to the gen 4.
#91
I don't want A, smaller and lighter. The 4Runner is only just big enough for my needs as it is. I would greatly prefer B, a turbo-diesel engine. But that's just not going to happen.
#92
good points, but it will help boost the critical fleet gas mileage for the CAFE program, and as BT17R said, its more for that than anything. I totally agree with you that Toyota needs to do A and B haha. Thanks for pointing out that the new 4runner is much heavier, I always forget that fact... lol
#93
4x2 is, by definition, lighter than 4x4 -- no front diff, no transfer case. The 4-cylinder is lighter than the V6 as well. So a 2wd 4-cylinder will be a couple hundred pounds lighter than a V6 4x4. Yes, a more highly optioned model will be heavier as well, due to things like motors for power seats, etc.
But the basic structure of the vehicle -- body, frame, suspension, etc. -- will be the same. So the weight difference will not be huge.
Furthermore, while lighter weight does improve fuel economy, the difference of a couple hundred pounds on a 4000+ lb truck just won't have much impact. Much of the poor economy of the 4Runner is due to aerodynamic drag, which is a function of the drag coefficient and cross-section, both of which will be the same on a 4-cylinder 2WD model as a 6-cylinder 4x4.
Will a 2WD 4-cylinder have a higher fuel economy rating than a 6-cylinder 4x4? Sure. How great a difference in the real world? My guess is not that much.
Up here where it snows, dealers wouldn't be able to give away a 2WD 4Runner.
#94
M1911, gearing will have a similar or greater effect than weight.
For example, the A/T FJ 4WD is rated 16/20, the M/T 14/19. Weights are within a few pounds. A/T overall final drive is substantially higher than the M/T counting the OD and final drive of 3.7 vs. 3.9 for the M/T. So the A/T FJ gains 14% better fuel economy through gearing alone.
I expect a different gearset and final drive for the 2.7L vs. the 4.0L. It'll be interesting to see the difference in EPA ratings. I'm guess at least a 20% improvement, but haven't seen the updated 1GR dual VVT-i ratings yet.
#95
#96
It depends on overall final drive. Sure it'll have shorter 1-2-3 gears, but I'm guessing at least one, maybe two overdrive ratios to pump up the EPA numbers.
#99
End of 4th Gen Production: 8/28/09 (Tahara)
5th Gen Production begins: 8/31/09 (Tahara)
1st VIN Visibility: 9/03/09
Ship to Dealers: 9/16/09
Wholesale/Retail Date: 9/15/09 (May be reported sold to customer)
PPO Available: 9/15/09
One per dealer initially, future availability earned based on dealer's previous 4R sales rate
Depending on dealer location, their first one on the ground will take between 7-14 days (Portland) or 28-35 days (Boston via Panama Canal)
#100
