2004 Horn -- HELP!
2004 Horn -- HELP!
I can't believe I cannot find the horn relay on my 2004 4Runner.
I hit the horn and it doesn't work. I replaced the fuse. It doesn't make a difference.
Anyone know where the relay is?? It's the only thing else that I can think of. Or am I missing something... (?)
Any help would be greatly appreciated... This is a mystery to me.
Mine is a '12 4Runner but I just happened to have an extra 'Relay/fuse box' from a '07 4Runner. EDIT: Sorry about that phoenix; when I started out, I understood that you were trying to locate the Horn Rly, but I pointed the fuse out instead. I just went through the Rly/Fuse Box that's on my work bench. I traced the (White w/GRN stripe) wire from the 10A horn circuit fuse to the wire bundle that leaves that box altogether; leading me to believe that the Horn rly may be located in the Driver-side fuse/junct box near the E-Brake. Now in my 4R that relay is in the main fuse/rly box under the hood, but yours may be different. I did a google search and a lot of late model Toyota's have their horn relay's under the steering wheel. Take a look at the cover on that box and it may be labeled! Cheers
Hope this helps, Rgds!
Ilovemountains
09-15-2015 04:17 AM
Highlander Giant
09-08-2015 06:46 PM
