streetlancer's 1987 Pickup Build-Up Thread
Although I'm a little late for this, considering the mods done already, I'll do it anyways.
Better late, than never!!
Here's the first one: (Obviously not the first mod, just the first one documented.)
Courtesy Light installation from a 4runner!!
and don't forget the bracket......it's held in by 2 bolts under the headliner:
First, this is what it looked like before...
after removing that i was fishing for the wiring and......ta da. I found i was already prewired for BOTH, which is great because it means i'll have more lighting.
After sliding the bracket in place and securing it with the two screws it was time to cut into the headliner...
I cut small xs into it and enlarged until it fit snug. (It took a couple of tries, i wanted the headliner nice and taut.)
And just because i like pictures:
Here i got the mirror back on and wiring the map light....
Trying them on (notice how tight the headliner is)...
Final product:
I chose not to use the plastic cover over the bulb as it originally came:
Now it's time for some leds!!
I am putting these links here in order to track and plan my build aswell as aiding other yotatechers with ideas:
63'' Chevys:
http://www.pirate4x4.com/forum/showt...threadid=20665
https://www.yotatech.com/forums/f116...ection-222692/
http://forum.ih8mud.com/79-95-toyota...ring-swap.html
Rear Disk Brakes:
https://www.yotatech.com/forums/f116...c-swap-107749/
https://www.yotatech.com/forums/f116...riteup-121582/
https://www.yotatech.com/forums/f116...inions-119850/
Rebuild Aisin Hubs:
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
Monster Ifs:
http://forum.ih8mud.com/79-95-toyota...ml#post2390957
http://forum.ih8mud.com/79-95-toyota...e-options.html
Idler Arm Brace:
Bumper Ideas:
https://www.yotatech.com/forums/f116...-heavy-193768/
Good CV Writeup:
https://www.yotatech.com/forums/f116...ctures-158106/
Final product:
63'' Chevys:
Rear Disk Brakes:
Rebuild Aisin Hubs:
Monster Ifs:
Idler Arm Brace:
Bumper Ideas:
Good CV Writeup:
You're right about those tires;too small. We might soon upgrade the front two to 31x10.5x15 GY Authoritys. The rear are pretty much new.
The guy before me had replaced the washer fluid sprayers (on the hood) with aftermarket ones that have red LEDs in them. In CT that's a stupid reason to be pulled over, and I'm not into that, so I've been thinking about swapping them out (or just cutting the leads). Anyway, if you are interested in swapping let me know they'd probably look pretty sweet on your rig.
mild body & susp. lift to accommodate 33s
4.88s with lockers
Sliders, Rear Tube Bumper with Spare Tire Carrier, Front Bumper with Winch
Budbuilt Skids
Yakima Roof Rack
Auxiliary Lights
And so on......
But it'll be a while before all this begins (still in highschool/ no money). That's why is not much of a build up more like a mod up. Right now the focus is tires, BL, and paint
Check these pics out:
Candy Apple Red!! Sprayed it in the back yard, i'm surprised no bugs stuck to it!!
And Just Because There are No Pics of the Truck in My Own Thread:
I've been experimenting with rustoleum paint after reading a couple of roll-on paint threads. It seems like a possible candidate considering a base/clear system will run me about $400 plus supplies and tools.
The results:
This was sprayed on with a paint gun/not roll on
Not bad. So far, it has been sitting outside for a month exposed to the elements and still looks fresh. If I end up going this way, it will only be temporary and eventually will get a b/c paint.
The results:
Update: Tinted the X-tra cab glass
I figured I'd get a better fit if i took the glass out and so I did:
These came out perfect, not a single bubble!!
Also these arrived at the house,
And went in here:
Dropped it a good 2'' and i can still go a 1/2'' lower
I took the old springs, which measured 11'', and installed those on the truck's leafpack to give me 1'' of lift!! Ill take pics of that soon!!
man the extra cab window looks perfect!!! the tint on mine is all bubbled up around the lil knob thing on the extra cab window. what percent is that to???
