| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#726 (permalink) | |||||
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#727 (permalink) |
got everything in the dash "mounted" today .. made all the little clips and mount brackets .. and welded them all in place . so now they can easly be removed , but wont be falling out .
I have also changed my plan for the dash .. I wont be doing the woodgrain .. I'm going to paint the main dash and center console the "inferno red" , same color as the outside , with the cover/pad being grey leather to compliment the interior all the dash trim is going to be painted black I now just have a few little dash lamps and such to wire , and I believe then , I am ready for the tear down .
__________________
#728 (permalink) |
Wow! It feels so close. I am excited to see this beast finished. As usual Slacker you are doing a great job.
__________________
1996 SR5 5speed rear locker. |
#729 (permalink) | |
Quote:
__________________
#730 (permalink) |
working on the passenger door .. hinges are re-pinned , and as of today , the old metal , dented and starting to rust skin has been removed .. I need to still clean up the interior of the door a bit .. POR15 it .. and then I can bond the new skin on
same process as the drivers door .
__________________
#731 (permalink) |
Hi there,
I have just joined this forum and I stumbled across this build up, I love the work you have done there, I am about to embark on a second rebuild of my 4 Runner but no where near the level you have gone to, not to mention we don't have a fibre glass manufacturing place here in Australia to do those panels, we have to find panels in good shape and use them. I wish you the best, not that you need it by the way it looks now, my hat is off to you. |
#732 (permalink) |
Thanks !! ..
I sent you a PM .
__________________
#733 (permalink) |
passenger door "epoxied" and curing overnight .. also got a little more done on the wiring .. had to add and move a few plugs for the lighter and such also got all 4 accessory ports wired .. drilled and set into place . I want to add the cup holders to the console , and maybe a "pocket" as well ..
have some pics up tomorrow .
__________________
#734 (permalink) |
ok so as suggested .. Right door is done and mounted ..
![]() and pics of the ports .. rears you can just see at the top of the rear of the console .. also the rear switch is installed .. ![]() ![]() and the cupholder pics will have to wait .. It's all done , but I ran out of batteries in the camera . also working on the guage wiring .. .
__________________
#735 (permalink) |
so cupholder in .. ;D
![]() also installed the oil pressure sender ![]() and got the guages wired .. (still have a bit to do) they will all be green -- to match the rest of the dash . ![]() .
__________________
#736 (permalink) |
I wish I had that sort of cupholder. Very cool.
__________________
-+-( 1993 Toyota XtraCab Pickup )-( SR5 3VZ-E 5spd 4x4 )-( 32x11.50A/T's HellaH4's )-( 360,000+km ) |
#737 (permalink) |
can you upshift or will you dogleg the shifter?
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#738 (permalink) |
yes .. console is not all the way forward in that pic ..
__________________
#739 (permalink) |
ok .. so I believe I'm all done the wiring now
.... Finished up the guages (now green) almost time to sauder all the cinnections , and tape and loom .![]() also did the new dome lamp in the rear , ![]() and a "walk-in " lamp wired to the auto shut off lamp system , I will install it down in the foot area when the time comes . ![]() .
__________________
#740 (permalink) |
Coming along very nicely, I think I will need to make up a new consul myself, the manufacturers don't cover the things I am looking to put in there, I think i have too many things in there for my own good, I try to give a look that says it was suppose to be there, rather than something added later sort of appearance. because I am using 3 radio's for comms, the 27meg SSB CB. the UHF CB. and the HF Codan set as well. plus all the entertainment stuff as well. not that it all goes into the consul, but like your dash, it has to look right before you can be happy. I am really enjoying this thread so keep up the great work.
#741 (permalink) |
thanks ...
__________________
#742 (permalink) |
Epoxied the dash , inside and out , and now ready for the final bodywork
__________________
#743 (permalink) |
so today the dash bezzles .. hi-solids primed twice .. and sanded once. .. I'm STOKED .. so far , they look awesome !!
i'm hopin' to shoot some black on them this weekend .. .
__________________
#744 (permalink) |
so I didnt get the dash pieces done this weekend , but I did get some more work on the center console done .. I built a little pocket , for the rear heater cold/hot leaver .. and started working on the arm rest with map holder pocket undernieth
__________________
#746 (permalink) |
dash is basically ready to go for paint and trim . I still have to finalize the gaps yet .. but basically done
here are the pics .... ![]() ![]() ![]() also .. trying to get all the little things done , I built the console arm rest , got it hinged and front latch , also the limit strap done .. and now also ready for trim/covering ... ![]() ![]() also working on the shifter boot mounting .. bent up a coat hanger into a square , and got it welded today .. figured out how I'm going to mount it .. just need to make some small clips ... .
__________________
#747 (permalink) |
Looking nice, good to see you're spending time on the little things that will be nice in the end. Keep up the good work.
__________________
The Daily Driver: 1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock The People-Hauler 1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock The Dump Runner 1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916 |
#748 (permalink) |
thanks ....
so some pics of the shifter boot mount .. ![]() here is the "ring" with the clips .. the shifter boot will be sewn to the ring , and the held down with the clips .. on to these studs . ![]() .
__________________
#749 (permalink) |
![]() do what i did
__________________
1988 p/u 4x4 22re all stock accept the new dents i put in the side of it, o/e clutch from toyota, timing chain kit, water pump, and the newest a blown head gaskit and it needs new rings wait for a rebuild thread! New Truck 88 sr5 22re with rancho's and a nice little towing package but the engine was knocking so i pulled the engine out and im gonna rebuild it |
#750 (permalink) |
__________________
| Tags |
| 1983, 7mgte, 81, bumper, control, craigslist, cut, heater, ramsey, roof, supra, toyota, trekker, truck, valve, wagoneer, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| slacker's 1st 1983 Trekker Build-Up Thread | slacker | Build-Up Section | 189 | 09-04-2009 05:46 PM |
| 1st gen runner(not mine) | kyle450rider | The Classifieds GraveYard | 1 | 11-08-2007 06:33 PM |
| FIND:1st gen in Flagstaff AZ for sale (Craigslist/not mine) | sdstud212001 | Off Topic Talk | 8 | 10-02-2007 07:04 AM |
| 1st gen 4runner or Toyota truck mudflaps for sale on ebay (not mine) | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 12-14-2004 08:47 AM |
