| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
So much to do, yet so little money. under construction: 82 Pickup still getting goodies build up thread: http://www.yotatech.com/f114/my-82-b...thread-158522/ parents commuter: 07 Camry, K&N, tinted windows, 135,XXX miles My other toys: 2008 Kawasaki KFX 450r, pro circuit exhaust, tusk black nerfs, tag black front bumper 2004 Suzuki Eiger 4x4, custom snorkels, 27 mudlites, warn 2500, uni filter |
#27 (permalink) |
Holy crap biskets! I thought I have seen it all! Air chisel? Maybe a drimmel tool. I love that style Toy, good luck.
__________________
www.stockardmaintenancesolution.com Leave the trail a cleaner place than it was before you got there |
#28 (permalink) |
bump it on up, any ideas on how it get it off?
__________________
#29 (permalink) |
Wow, just... wow. I have never seen that in my life nor would I ever do that unless it was a dire emergency and I needed to do it get home or to safety.
Well, it has to be replaced, im sure the threads are shot thanks to the welded on nut. About the only thing I can think of is grinder/dremmel like he said.
__________________
1980 Toyota Hilux 4x4 pickup 22r/20r Hybrid engine Crawler Cam WEber 38 carb (Thanks Roger!) 32" Hankook Dynapro MT's Acura Integra bucket seats Future mods: 4.3 Vortec V6 700R4 Tranny with 4x4 shift kit 35" MT's R.U.F. swap with 63" chevy's Custom computer tune Magnaflow exhaust Much more to come... |
#30 (permalink) |
An easy way to tell what gears you have is if your speedo works. I had stock gears and when I put on 33's my speedo was off about 10 miles per hour at 60 miles per hour. When I put 4:88's in the speedo is just about on with 33's.
__________________
1983 Toyota SR5 Short Bed 4x4 3" suspension lift, 1.5" body lift 33x12.50 Firestone Destination M/T's Front and Rear Aussie Lockers 4.88 dif gears 4.70 Crawler tcase gear Stock 22R Hedman Header Custom Bumpers, Warn Winch |
#31 (permalink) |
wow...1st time i've seen a spindle nut WELDED on....
x2 on the air chisel then get a big tap & die set
__________________
87 Toyota 4Runner 22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time... 79 Toyota Longbed 4x4 Frame-off Resto time. 04 GMC Sierra 1500 the DD |
#32 (permalink) |
my buddy has a junk axle off a 84 or 85, so i will pull a new spindle and junk off of it.
__________________
#33 (permalink) |
Alright my new birfields came in the other day, so when you grease them how do you do it? Just pack as much grease as you can in and around it?
__________________
#34 (permalink) |
anyone know?
__________________
#35 (permalink) |
Yeah, just get a bunch in the palm of your hand and pack it into the sockets for the balls. Rotate the birfield around and keep packing the grease into it good and deep. Some guys just pack the birfield and leave the knuckle fairly dry so trail service isn't so messy. I myself not only pack the birf, I pump a good amount of grease into the knuckle after assembly aswell.
__________________
1985 Extended Cab: 22re, 5spd, |
#36 (permalink) |
By the way I want to punch the guy that welded your spindle nuts.
__________________
#37 (permalink) |
I fill them both slap full.
Did you get your long and short shafts off of the Birfields already? Do you know how? Do you know how to put the new birfields on the old shafts? If not just ask.
__________________
1980 Toyota Hilux 4x4 pickup 22r/20r Hybrid engine Crawler Cam WEber 38 carb (Thanks Roger!) 32" Hankook Dynapro MT's Acura Integra bucket seats Future mods: 4.3 Vortec V6 700R4 Tranny with 4x4 shift kit 35" MT's R.U.F. swap with 63" chevy's Custom computer tune Magnaflow exhaust Much more to come... Last edited by scooper; 12-13-2008 at 02:25 AM. |
#38 (permalink) | ||
Quote:
Quote:
How do you get your old birfields off and the new ones on?
__________________
#39 (permalink) |
ok, there is a snap ring on the inside of the birfield that clips on the end of axle just like the one inside the hub. It sits int he grooves but is just big enough to stop the axle from being able to be pulled out by hand. The easiest way to do this is to get a length of pipe 2" or 3" , metal. clamp it in a vice or some how manage to hold it steady. Then you hold the lift the birfield with the axle shaft pointed down. place the end of the shaft into the round pipe and slam id down firmly while still holding onto the birfield.
__________________
#40 (permalink) |
I took the bolt in the fill hole on top and replaced with a grease fittings so I can just grease everything all the way around with a grease gun. It was a little tricky getting them in because I didn't have everything apart when I did it. Just a thought, made life a little easier IMHO.
__________________
Jason 83 SR5 4x4 shortbed (Project) 91 DLX 4x4 xcab auto (Daily Driver) "Prosperity will have it's season, even when it's here it's going by; when it's gone we pretend we know the reasons, but all the roots grow deeper when it's dry." David Wilcox |
#41 (permalink) | ||
Quote:
Quote:
Yall are genious, I bought a air chisel and hit it on the welds and they flew off like there was never anything there.
__________________
#42 (permalink) |
Time for an update.
Well I have had little time to work on the truck between going to school full time and also working full time. I finally got one side of the front axle put back together, but I have to go to my buddies house to get a spindle off a spare axle to finish the other side. Hopefully in the next month I will have it back driving again so I can show some of my buddies up. Oh one other thing that I found out, brake parts cleaner doesn't feel good when sprayed into your eye.
__________________
#43 (permalink) |
good lookin 1 st gen. i started a build on one, but lost intrest. i still have most of the cab and front clipif you run in to the need for them. if not then the crusher may meet them over the summer.
#44 (permalink) |
another update:
I had today off and got my truck back to the point where it sits back on all four wheels again!!!! I also started it up, first time in a lllloooonnnngggg time. It ran like a champ, I will be hopefully getting it out the garage wednesday on my day off. I can't wait to take it out and start having fun again, it's been about a year since I drove it. I'm going through withdraw.
__________________
#45 (permalink) |
another update:
Well I got lucky and ended up with some civic seats today for free. I'm off again wednesday and I'm gonna pull the truck out and get some pictures and what not.
__________________
#46 (permalink) |
Wow you guys order from marlin from way out there I'm only about 45 min away from them over her in Dinuba Ca. I didn't know yall even knew about marlin crawler I never heard any out of staters talk about them. I just rebuilt my 84 frontend last week so mutch fun when your doing gears.we hope to see those pix soon buddy.
__________________
yota4life Last edited by mikepr55; 02-22-2009 at 09:22 PM. |
#47 (permalink) | |
Quote:
__________________
#48 (permalink) |
Yeah it's mostly california people on the Marlin forum but there are people from all over the world on that site. Most people I know who are into Toyotas & offroading, and have internet access know about Marlin. He's the man!
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#49 (permalink) |
![]() ![]() ![]() ![]() I cleamed out the garage and had it move my spare trans, that motha was heavy ![]() My other toys
__________________
#50 (permalink) |
Ohoooooo. Snorkels on the quad! Nice! Got any pics of you puttin' them snorkels to work?
__________________
1982 2wd Pickup - Custom Interior - Pioneer 8" subs 1990 4runner - Blown Head Gasket Mod (fixed!) - Cruiser Coils - BJ Spacers - Bed Lined Fenders - CB/PA - Alpine HU - H4 Headlights - 2 15s and a Rockford amp. 1996 Camry - 400,000 miles on original engine/transmission. HELL YES!!! All it takes is a quart of oil with every tank of gas. Project: scratch building a modernized Lotus 7 replica using a 22-re Celica drivetrain |
| Tags |
| 1982, 4x4, 82, box, dog, drag, fit, link, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hayes' 1985 4Runner Build-Up Thread | Hayes | Build-Up Section | 83 | 05-10-2009 08:19 PM |
| UKMyers' 1994 4Runner Build-Up Thread | UKMyers | Build-Up Section | 209 | 04-13-2008 03:35 PM |
| Tacoma750's 1986 Pickup Build-Up Thread | Tacoma750 | Build-Up Section | 3 | 08-29-2007 01:42 PM |
| The 3.0 build-up thread | suprathepeg | 86-95 Trucks & 4Runners | 137 | 07-30-2007 09:19 AM |
| navyredneck's 1995 4Runner Build-Up Thread | navyredneck | Build-Up Section | 13 | 07-05-2007 01:04 PM |
