| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#27 (permalink) | |||
Thanks!
Quote:
More than once! It's even cooler when it's boosted up, and you always know EXACTLY how fast you going. As for the 85' 4Runner, it got cut up last weekend (RIP) and I'm in the process of storing/selling the parts.Quote:
Quote:
, but it's for the best. The front axle will be going in it, other than that I'm still working on the details. This 4Runner will have to sit a little taller (so that I don't have cut the body), the suspension will have to be changed around a bit from the last truck.
__________________
The new project and daily driver 86 Turbo 4Runner, The "Luxury Crawler" http://www.yotatech.com/f116/86-turb...-build-155840/ The old Trail Rig - RIP 85 4Runner, Bobbed, Dovetailed, 37's, Dual cases, the list goes on. http://www.yotatech.com/f115/85-4run...thread-134399/ |
#28 (permalink) |
3" lift in the front and 4" in the back gets my runner with no rubbing. I have a bent front hanger on the driver's side that makes it hit the pinch when I am turning. I have 33", I know you said you wanted 35" so maybe 4" front 5" rear...
__________________
#29 (permalink) | |
Quote:
Before I took the picture's I cleaned it up and waxed it, it's not perfect by any means but it is in very good shape. I will be taking care of this one, the last one I knew would get destoyed (even when I first started building it). That's why it has to be capable and be able to get itself out of trouble without getting crazy, and taking out the sheet metal.
__________________
#30 (permalink) |
I envy you so much that if envy were people I'd have enough folks to start my own army and take over China!
That runner looks great. Keep up with the pictures, more welding less typing!!!!!
__________________
RB4R Life Member. 1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header. |
#31 (permalink) | ||
Quote:
Quote:
I'm still working on the details of the transmission, I do know that I will be keeping the dual cases (or worst case, going to a single 4.7 case). I've been checking out the Inchworm adapter but everything I find is pretty much lacking the info I'm looking for. The auto is comfortable and with gearing I'll be able to eat ice cream and popsicle's while driving over rocks (I'm just joking, ... but seriously, you never know) The only thing that sucks about the auto is how gutless it is taking off from a stop and the random gear shifts at the wrong time. The other issue is that I don't want to hack up the Turbo 4Runner and I want to keep the rear heater. With a manual transmission you could run a trpple shifter and keep any cutting to a minimum.As for the suspension, I don't want the thing to set super high. The last 4Runner sat SUPER low, I know that's not possible with this one but I would like to find some common ground between the two and keep it as low as possible. Do you have any pictures of your rig that I can compare lift and clearance to? Most of the suspension picture's I've seen are after the install, it would be great to see some after some normal wear and tear.
__________________
#32 (permalink) | |
Quote:
I got the Co2 tank and bracket mounted up, I wanted to keep as much room as possible. ![]() ![]() ![]()
__________________
#33 (permalink) |
Hey man nice truck. I had 2 86 Turbo Runners at the same time and sold them both very quickly (long, sad story
) one of them is my user picture. It was immaculate! Anyways just wondering the kind of mileage you were getting, thats the reason I sold mine, I was getting 12mpg at worst and 13mpg at best. I think it was the fact that they were both automatic transmissions and both the transmissions were screwed. I really wanted to swap in a manual but money was tight. (hence, they are gone)
__________________
1982 2wd Pickup - Custom Interior - Pioneer 8" subs 1990 4runner - Blown Head Gasket Mod (fixed!) - Cruiser Coils - BJ Spacers - Bed Lined Fenders - CB/PA - Alpine HU - H4 Headlights - 2 15s and a Rockford amp. 1996 Camry - 400,000 miles on original engine/transmission. HELL YES!!! All it takes is a quart of oil with every tank of gas. Project: scratch building a modernized Lotus 7 replica using a 22-re Celica drivetrain |
#34 (permalink) |
My rear springs only have a couple hundred miles on them at most. I just got the new engine in it, so I will start getting them to settle. Also, my rear shackle angle is horrible and making the rear sit higher.
I found that 3" lift springs in the rear sat too low with the topper on, 4" sat much more level.
__________________
#35 (permalink) | ||
Quote:
anyways, nice build, and like junker said, more welding less typing!!!
__________________
Trailer Re-Build - Check it out!!! Quote:
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack |
#36 (permalink) | |
Quote:
. I'm sure there's more to it than that though.I get between 19-20 on the highway, I don't really know what I get around town but I don't think it's much less.
__________________
#37 (permalink) | |
Quote:
__________________
#38 (permalink) | |
Quote:
It works and sounds good, so I have never replaced it. I'd rather spend my money on something else for the time being.
__________________
#39 (permalink) |
One thing about my setup is that the ONLY things that have been replaced on my lift is the springs and shocks. I have stock shackles, stock mounting locations, etc. etc. On the front of the rig you just posted it has this for the fronts along with longer shackles.
__________________
#40 (permalink) | ||
That red truck looks like it doesn't know what's gonna hit it. I've never seen so much body damage. Either you're a terrible driver, or very dedicated.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#41 (permalink) |
Dedicated it is!
__________________
#42 (permalink) | |
Quote:
__________________
#43 (permalink) |
That's what I was getting at. Hope my blabbing helped you out a little.
__________________
#44 (permalink) | |
Quote:
__________________
#45 (permalink) |
Good, We should wheel it when you get some work done on it. I'd love to see it in person!
__________________
#46 (permalink) | |
Im liking th speaker boxes in the back
Where did you get the idea? lol did you make the maglight mounts, or did you buy them?
__________________
1985 Toyota 4Runner SR5 4WD red, mostly stock, mossy oak seat covers, custom stereo system, Dixie Horn, Custom Rear Bumper Build Up Powder Springs, Georgia Quote:
#47 (permalink) | |
Quote:
I knew the last 4Runner was going to end up like that, I just always thought I'd be able to get a tow rig and trailer one day. Dedicated is a pretty good way to describe it. I was dedicated to run trails, that at the time, I wasn't built enough for (Carnage ) and in the process the body got a little beat up. But the more body damage you get, the less you care and by the time the was built the way I liked there was hardly any body left.The Turbo 4Runner is going to stay nice!
__________________
#48 (permalink) |
Hey you have carpet on the cargo floor. I have vinyl for some reason carpet everywhere else.
Also I have the rear seat delete in mine and its red......lol ![]()
__________________
86 Toyota 4 runner Soild front axle, 35x12.5 BFG KM2's, winch, blah blah blah.... http://www.yotatech.com/f116/my-new-red-snappah-152938/ My cardomain page Last edited by 934rnr; 10-04-2008 at 08:58 AM. |
#49 (permalink) | |
Quote:
The Mag-light clips I picked up at the hardware store a couple years ago, I think they were less than $5.00.
__________________
#50 (permalink) |
Yea, we'll have to get together once it's done, or if your ever in the area let me know. There are plenty of trails around here that are perfect for a 4Runner on 33's like yours!
__________________
| Tags |
| 1986, 1994, 300000, 4runner, 4x4, 86, build, builds, cluster, digital, dovetailed, ideas, miles, run, toyota, turbo, unit |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| trd90toyota's 1985 4Runner Build-Up Thread | trd90toyota | Build-Up Section | 36 | 12-14-2008 07:09 PM |
| New Member w/ 86' SR5 turbo | jbone | Introductions & New Arrivals | 4 | 05-13-2008 07:51 PM |
| 86 turbo build | turboyota1 | 86-95 Trucks & 4Runners | 1 | 04-04-2008 10:28 AM |
| Picked up a new 86' turbo | BlazenOffroad | 86-95 Trucks & 4Runners | 6 | 01-18-2007 11:39 AM |
| Mike at XTREME: Did you help build this turbo Civic on ebay? | rimpainter.com | Off Topic Talk | 7 | 03-20-2005 12:24 PM |
