904_runner's 1990 4Runner Build-Up Thread - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Build-Up Section > Build-Up Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2008, 10:40 PM   #1 (permalink)
904_runner's Avatar
Okay heres the deal, after long consideration on what my plans are for this truck ive decided to SAS it like so many others have done. My plans are to have this done sometime this winter, but we will see what will happen, since we all know life happens and money cannot always be spent on the rig.
Currently ive purchased an 85 SFA and am starting to build it. The first night we picked it up, we tore it down in a few hours and since then ive painted it and am starting to get the knuckles back on.
Pictures are to follow....
Cliff notes:
Engine:
-3.4L swapped from a 99' tacoma.
-Custom made crossover pipe/exhaust
-cone intake
-Magnaflow high flow cat
-Magnaflow muffler
Front Axle/suspension:
-Housing trussed, Marlin knuckle ball guessets, diff armor/extended breather.
-Stock birfs for now. Longs coming soon..............
-Completely rebuilt
-FJ Rotors and ifs brakes
-Trail gear high steer
-4cyl Diff w/ Yukon 5.29's and a Detroit ez Locker
-12" travle Bilstein 5125 shocks
-Trail Gear 4" springs
Rear Axle:
-Diff Armor
-Yukon 5.29's with lockright, set up by ZUK
-63" chevys custom pack, 7" shackles and a 2" block.
-Rancho 9000's for now, bilsteins soon to come.
Transmission:
-R150f with 263,000 original miles.
-Super heavy duty marlin crawler clutch (2100 pound pressure plate)
Transfercase:
-Stock v6 chain driven for now. Duals to come shortly.
Armor:
-Trail gear sliders
-Trail gear front bumper
Interior:
-Cobra 18wsxtII Cb
-Kenwood stereo deck
-4" polks up front
-6.5" generic speaks out back
-10" boston sub going in shortly.
Wheels/tires:
-35" pro comp xterrains
Deciding between 39.5" iroks or 39.5 pitbull's.
-Eventually plan to do a weld on bead lock kit.
__________________
Mike
1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd
Longfields, Duals coming soon:
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
http://www.treadlightly.org/
http://www.pirate4x4.com/tech/billav...ery/index.html
904_runner is offline
Old 11-08-2008, 10:53 PM   #2 (permalink)
904_runner's Avatar
Okay heres some pics:
Heres the axle, the night i picked it up!
About three hours after getting it in the garage we got it down to this:
Next day we started, wire wheeling it, and i picked up a 4" angle grinder and some cutoff discs and started cutting off unnecessary brackets and grinding it smooth. (85toy using the angle grinder)
Here you can see where somebody torched off a bracket before i got it and got a bit of the housing. Ill fill this in when i get my hands on a welder, this would be under the area where the upper truss will go.
After we got it all ground down smooth, to the best of my abilities, i gave it a few coats of primer.
Gave it a few coats of flat black paint:
__________________
Mike
My build thread
Old 11-08-2008, 11:08 PM   #3 (permalink)
904_runner's Avatar
So i ordered some parts from marlin! Got them next day!
Knuckle rebuild kit, wheel bearings, upper truss, knuckle gussets, Marlin heavy duty inner axle seals, and a pull scale!
My first box of goodies towards the project! Thanks marlin!
Comparison shot between factory inner seal (left) and marlin's heavy duty seal (right). Look how much beefer Marlin's is!
So heres how it practically sits now!
I have put one knuckle on and will get the other one on maybe tomorrow. I put the factory steering arms on at the moment and they will have to be pulled off and exchanged when i get the hi steer parts. But the more im around this axle the more i learn about the workings of it. Im kind of at a halt until i can get the kit so i can completely get the axle back together.
As of yesterday i had just under the amount needed for the sas kit, but i finally got around to inspecting the howling from my rear diff, and it turns out the pinion bearing is out. I had the diff rebuilt about 6 months ago and the guy who did it was very cool about it and is warranting his work and will do it again for free. He was not sure what happened, for he said he had the preload and other things setup perfectly. Ive heard many good things about his work and don't question it at all. I was contemplating regearing for a while and the guy said he would do that also for no extra cost. I find it very cool for someone to stick to their word and do this without wanting any more money than what i paid him the first time. So i will be doing business with him again!!!
So i ordered some 5.29's yukon's and another install kit from marlin and will hopefully get this thing done in the next week. As of now i only ordered the gears for the rear, i am trying to find an already setup third with 5.29's for the front to try to save some money.
Marlin is most likely having no problem taking my money in exchange for parts, for a few days ago my clutch master cylinder went out and i bought one from them too!
My marlin stickers are adding up!
__________________
Mike
My build thread
Old 11-08-2008, 11:15 PM   #4 (permalink)
algranger's Avatar
beautiful but its gonna be hard to weld throught that fresh paint
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 11-08-2008, 11:18 PM   #5 (permalink)
904_runner's Avatar
Hahaha, i know. Anxious i guess! lol
Im gonna sand around the area where i will have to weld and then paint over the truss when its done!
__________________
Mike
My build thread
Old 11-08-2008, 11:26 PM   #6 (permalink)
904_runner's Avatar
This will hopefully be one of the last wheeling trips i do on my ifs!
__________________
Mike
My build thread
Old 11-08-2008, 11:28 PM   #7 (permalink)
algranger's Avatar
guess it coulnd hurt to have a little rust protection underneath the truss
__________________
I said lie, for me
Old 11-08-2008, 11:53 PM   #8 (permalink)
904_runner's Avatar
Thats what we were going for. Who knows! lol
I won't miss this! Check out the front flex!
__________________
Mike
My build thread
Old 11-09-2008, 12:11 AM   #9 (permalink)
scuba's Avatar
We gotta see the rear shot
You should send me some of that marlin flair
Ill actually be ordering one of those MC's from MC... Soon..My O'rielys unit likes to leak after 6 months...ghey..
/thread spaming...
Cant wait to see the finished product mikey
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 11-09-2008, 12:14 AM   #10 (permalink)
904_runner's Avatar
Yea same here. i can't wait but at the moment i haven't even really started.
Yea the Master cylinder was such a PITA. Trying to get that linkage back onto the pedal was the worst part, but marlin sells ASIAN MC's, and the local dealer wanted $120 and a 3 day wait, and Marlin's was like $70 after shipping and taxes and got it the next day!
__________________
Mike
My build thread
Old 11-09-2008, 03:39 PM   #11 (permalink)
scuba's Avatar
I care about your thread !!!
__________________
scuba is offline
Old 11-09-2008, 08:09 PM   #12 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
glad you're starting the build dude, i'll be following this one.
p.s. cage your truck.
__________________
-Mikey-
1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club
Poly Performance
4RunnerKid is offline
Old 11-09-2008, 08:14 PM   #13 (permalink)
904_runner's Avatar
Thanks!
and about the cage, ive been contemplating one for a while, but i wonder if a marlin one would really help or not???
I really wanted to make mine look like yours!
__________________
Mike
My build thread
Old 11-10-2008, 03:34 PM   #14 (permalink)
904_runner's Avatar
Okay, just got off the phone with marlin crawler and my 5.29's have been sent out today.
I will hopefully get them tomorrow and then i can pull the rear third and bring it to the shop and have them installed.
Still looking for another 5.29 third that i can use up front for my sas. Let me know if you have anything near chico California! Thanks!
__________________
Mike
My build thread
Old 11-11-2008, 03:41 PM   #15 (permalink)
85toy's Avatar
yay i get to be part of a build thread! nice start.
__________________
1984 toyota pickup extended cab 4x4
couple of mods
Quote:
Originally Posted by Getsome View Post
Tuesday black tar herion night.
85toy is offline
Old 11-11-2008, 06:54 PM   #16 (permalink)
904_runner's Avatar
YUP!
Dropped of my diff and 5.29 yukons off at the shop to have them installed. Hopefully it will be done soon!
__________________
Mike
My build thread
Old 11-11-2008, 07:44 PM   #17 (permalink)
4RunnerKid's Avatar
Quote:
Originally Posted by 904_runner View Post
Thanks!
it will keep what happened to me from happening to you, and you can always build off of it later. i say worth it.
i'm flattered you want yours to look like mine... that means a lot to me. pre-roll though, right?
__________________
-Mikey-
Poly Performance
Old 11-11-2008, 07:50 PM   #18 (permalink)
904_runner's Avatar
Yup pre rolled alwyas good!
haha. Theres soo much i want to do to my rig, its not even funny. The only thing stopping me, as i am sure for most of us, is money.
So at least when i sas it it will be the major start of customizing!
Every sick rig i see, i want to make mine look like it! hahaha
__________________
Mike
My build thread
Old 11-12-2008, 11:25 AM   #19 (permalink)
85toy's Avatar
hey let me know when you get your 3rd back and ill come help/watch you install it haha.
__________________
couple of mods
85toy is offline
Old 11-12-2008, 08:13 PM   #20 (permalink)
904_runner's Avatar
Cool! When you getting that aussie?
Okay. so heres some new pics...
My new gears!
And how it sits now, except the door is shut!
The guy who is setting up my gears said they will be done by this weekend. Which is great, since he is super busy and im not paying for labor again.
So i need to start cleaning out the axle housing for the second time. Do any of you guys use an additional magnet in the housing to collect some of the metal particles?
__________________
Mike
My build thread
Old 11-12-2008, 11:21 PM   #21 (permalink)
904_runner's Avatar
BTT, maybe someone else will read this and can offer up any advise to my sas.
__________________
Mike
My build thread
Old 11-13-2008, 08:35 AM   #22 (permalink)
4rnr's Avatar
Ill keep my eye on it. But looks good so far.
__________________
poop
1988 stock 4runner, v6, 5spd, soft top.
1990 fj62 stock and mint!
1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system.
The build up...http://www.yotatech.com/showthread.php?t=74915
4rnr is offline
Old 11-13-2008, 04:19 PM   #23 (permalink)
85toy's Avatar
supposedly its supposed to be here on tuesday, but ive heard that aussie has trouble getting there stuff out on time so who knows.
__________________
couple of mods
85toy is offline
Old 11-13-2008, 07:11 PM   #24 (permalink)
904_runner's Avatar
Thanks 4rnr!
and i hope you get that locker soon Travis.
Got my marlin knuckle gussets today, so now i need to get my hands on a welder to put theses gussets on and need to find a 5.29 third for the front SFA.
Then i can Finish putting the axle together and wait for the SAS Kit.
Oh, hopefully in the next week or two i can order the kit. Almost there!
__________________
Mike
My build thread
Old 11-13-2008, 08:04 PM   #25 (permalink)
85toy's Avatar
EEK its not even mine and im excited lol.
__________________
couple of mods
85toy is offline
Tags
4runner, 904runner, build, mikes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1989toy4wd's 1989 Pickup Build-Up Thread 1989toy4wd Build-Up Section 137 03-02-2009 11:23 PM
Tacoma750's 1986 Pickup Build-Up Thread Tacoma750 Build-Up Section 3 08-29-2007 01:42 PM
The 3.0 build-up thread suprathepeg 86-95 Trucks & 4Runners 137 07-30-2007 09:19 AM
navyredneck's 1995 4Runner Build-Up Thread navyredneck Build-Up Section 13 07-05-2007 01:04 PM
Had to start My own build up thread. RED 85 The Fab Shop 23 01-20-2006 09:07 PM
2009 InternetBrands, Inc.
