2001 4Runner 4x4
2001 4Runner 4x4
Finishing out the part-out of a 2001 4Runner SR5 4x4 AT with 78,000 miles that I purchased as a running donor for a 3.4L swap. The parts listed below are all that I have left. All prices listed are negotiable and I'm ready to make a deal on bulk buys. All prices listed are pre-shipping, which will be paid for by the buyer. All parts will be shipped from zip code 80526. I have pictures for every part on the list so please let me know if you'd like me to post or IM something specific. I will update the part list once an item is sold.
- Front driver and passenger quarter vent windows - $50/both
- Air bag sensor assembly (89170-35120) - $40
- Steering wheel air bag assembly - $50
- Engine Control Unit 4x4 AT (89666-35420) - $100
- Passenger side dash air bag - $50
- Radio Amplifier (86280-35080) - $25
- Gas filler door & cap - $15
- Dash gauge cluster trim (black) - $15
- Washer fluid pump (85330-35070) - $15
- Buzzer (89747-35010) - $10
- Antennae Relay (85914-35010) - $10
- Yaw Rate Sensor assembly (89180-35010) - $40
- Running light relay assembly (82810-04011) - $20
- Tailgate power window motor (85710-35110) - $30
- Horns (2) - $10/both
- Rear wiper motor assembly (85130-35070) - $30
- Single door lock switches (2) - $15/ea
- Hood hinges (2) - $10
- Front windshield wiper frames (2) - $10
- A/C compressor - $50
- Throttle body - $50
- Driver front window regulator motor - $30
- Driver side exterior door handles (front & rear - forrest green) - $15 both
- Front door speaker assembly (1) - $10
- OEM MAF sensor (22204-21010) - $40
- Assorted relays (90987-02012 six; 82642-35010 one; 85926-30020 one; 90987-02006 one) - $25 all
- Dash board filler plugs tan (1 large, 3 small) - $20 all
- Flasher - $10
- Traction control switch - $10
- Hazard light switch - $10
- Heater assembly (87110-35040) - $75
- AC cooling unit (448800-4620) - $75
- 4wd control computer (89533-35170) - $40
- Harness assy, towing converter (08940-35810) - $30
- Box of body harness pigtail connections (nearly complete) - $75
- Engine wiring harness (missing one ECU connector from swap) - $125
- AC condensor - $30
- Front driver side door glass - $30
- Rear driver side door glass - $30
- Sunroof glass - $50
- Front Passenger door (complete - forrest green) - $60
- Front & rear driveshafts - $60/both
- Fuel tank with pump (complete) - $60
Thanks for looking!!
- Flasher - $10
Well not sure on the technical name for the part I'm looking for, but there's a little rectangler body filler under the head light. I'm missing the one on the drivers side or my 4Runner. Any chance you have that and are willing to part? I can post a picture also if needed.
Sorry for the late reply but I do not have this part. Thanks!
Hey,
Looking, not sure if I missed it from your list, but here is what I am looking for:
center dash vents
Sunroof assembly-specifically the copper tubes/wires that pull the window-If it worked. Mine are frozen
Intake hose-goes from airbox to intake.
Shipping would be to 29860.
Thanks.
center dash vents
Thanks.
