FS[PacNorWest]: 1996 4runner part out-Camburg, ARB, Yukon, Sierra
Parting out my 1996 3RZ powered 4Runner with 284K miles. I WILL NOT BE REMOVING ANY PARTS UNTIL THE WEEKEND OF NOVEMBER 2ND. Sorry for the inconvenience. Rebuilt motor and trans plus many other newer parts. Found stress cracks in body where lift pucks make contact. Therefore I am not comfortable selling as complete. I will post pics as soon as I can of the parts. I am keeping the sliders and switch panel. All other parts are up for grabs. Let me know what you need. I have never wheeled this thing hard or beat on it like an angry teenager.
Prefer you email me at northman555star@gmail.com. But will check pm’s here when I can. I have posted this on CL, Pirate, and T4R. So first come first serve. Remember I have to actually pull these parts myself. My time is valuable so please take this into consideration in regards to my prices. I can ship parts via freight anywhere. If you don’t see what you want listed shoot me a message. I may have it.
And if you are local you are welcome to help me pull the big parts if you want them. Like the motor, trans, etc.
2.7L 4 Cylinder motor rebuilt 44K miles ago by Putney/22RE Performance in Chico, CA. Head was slightly ported. Runs excellent and has great power! Will come with all accessories (A/C, PS, etc.) except header and ECU. Motor rebuild cost was $3,000.00 plus all the new parts to install. New water pump, etc, etc. Needs rear main seal- $2,500.00
W59 Manual 5 Speed with T-Case and marlin HD clutch. Trans only rebuilt by Marlin Crawler 20K miles ago. The rebuild alone cost me $1,500.00. Will sell trans, t-case and clutch for $1,700.00
Doug Thorley ceramic coated header and collector- $200.00
High fllow aftermarket Cat and muffler 10K miles on them (original stolen by crackhead)-$150.00
Radiator with Taurus electric two speed fan, no controller for fan. Installed new at time of motor rebuild- $125
Odyssey battery and disconnect switch. Installed two months ago- $200
Front differential with 5.29 Yukon cryogenically treated gears-$250
Front driveshaft. Regularly serviced-$75
Front axles, one stock other Napa lifetime-$40 each
Rear differential with 5.29 Sierra gears and ARB air locker. Gears are brand new with zero miles. Had ARB rebuilt at same time. Work done by Central 4WD in Santa Cruz to the tune of $600.00. Comes with ARB switch, air lines, and solenoid-$1,500.00
Rear axle with all new OEM u-joints and double joint ball/bearing. Cost over $350 to have done at Napa machine shop a month ago-$325.00
Rear housing with axles and brakes 284K miles-free
Stock rear differential with 4.11 gears-120K miles-$100
Rear axle housing and axles with brakes/links/bushings in excellent condition-120K miles(bought this to run while my arb diff was being rebuilt)-$50
Viair 100% duty cycle air compressor-$125
Viar 2.5 gallon air tank with pressure relief valve-$50
Air pressure switch-$20
Air pressure regulator-$15
Marlin Crawler short throw shift kit-$100
Camburg upper control arms with uni-ball-$325.00
Tundra big brake upgrade front -$50
Sonoran steel 3" suspsension lift installed 4 years ago. Excellent. (System 1.2)- $600
Energy Suspension front sway bar bushings-free
Rack and pinion-$50
Four Goodyear MTR/Kevlar tires and moto metal skull wheels 75% tread. 315/70/17. 5th moto metal skull wheel with spare Interco TrXus 35”. Don’t want to separate-$1,100.00
Roof rack local pick up only-$50
Hi-lift 60” jack local pick up only-$40
LED Truck lite driving lights-$40
Interior is in ok condition. Will post up pics soon. Let me know what you need.
Rack and pinion-$50
