1986 SR5 4Runner part out
I drove this for the past 3 years as a DD, located in ND. Jumped the timing chain and I don't want to put any more into it since the body is rotted.
Interior is gray with PW,PL,Sunroof, Altimeter (with dash in very good condition), Cruise,
Rear Heat (blower for rear heat doesn't work, but the center console is for rear heat), 22RE, 5spd, smittybilt front tube bumper (bedliner),
toyota step rear bumper (bedliner), Pretty much everything is there except the shift trim and I'm keeping the SR5 cluster for another build.
I even have the ultra-rare SR5 12v trouble light and pouch.
Everything else is stock except for stereo and 2" body lift.
shifter trim pending ($100)
I'll check the radio brackets, I don't know if they have been modified ($20)
I want to sell the inclinometer with the dash, dashes are hard to sell without. Inclinometer is flawless (hood too). The dash doesn't have any cracks at all, but has a small cut above the glove box. The altimeter itself is from an 87, so it doesn't say "Toyota 4WD" but the hood is an 86 so the back side notch is the same as the dash. $300 for the pair
1 Post
Id also be interested in the A/C parts as well as the altimeter, and potentially parts of the dash to make it worth your while (i know you said you wanted to keep altimeter with the dash). If you would be willing to ship
thanks
thanks
Are the door panels still in good shape (the cardboard)? And the plastic trim on the inside of the B pillars? The Steering Column cover? The Moon Roof latch assembly? Center Console top?
Badlander - if the driver's floor board is good, would you consider cutting a piece for me? I can get you a pic and some measurements on size of the piece I need, but I've got a hole in mine right in the curve of the floor behind the brake.
