Highlander KS signal, please help
I have this Toyota highlander manufacture 2004, it has just thrown out check engine light with the vsc and trac off light on, i quickly hock my scan tool to the dcl connector and draw the code which states, P0328 - Knock Sensor 1 circuit high input (bank 1 or single sensor).. i have tried to look out for this sensor on bank one of the engine block but i could not find where its located on the block, this is my first time of searching such things on toyotal but i have known knowledge of it location on vw cars, so i thought its possible to locate on Toyota cars, but i could not find it, so if someone could help me with detail step by step of directing and showing me where its located i will be grateful, as i am away that on many forum information read, that if such issue happened, the engine code must be solve first, and if its done, it could trigger off the vsc or trac off, so please help me locate here this KS sensor is on this single block engine..
kawazx636
10-06-2021 03:03 PM
justdifferentials
14
06-11-2017 08:36 PM
Scotttekoch
09-28-2015 10:30 PM
Boomer8404
09-24-2015 01:12 PM
