Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
2010 camaro ss build
Old 09-29-2014, 09:09 PM
lemonth68's Avatar
Helping my brother turbo his camaro along with comp cam, port polish heads with new valve springs, rods, torque converter, injectors. I'm sure I'm letting some stuff out. Just got started and this is my first V8 build. I'll try to post as much as possible.
[ATTACH]99850[/ATTACH
I
Attached Thumbnails 2010 camaro ss build-forumrunner_20140930_000805.png   2010 camaro ss build-forumrunner_20140930_000823.png   2010 camaro ss build-forumrunner_20140930_000855.png
Old 09-29-2014, 11:47 PM
totally a bro
Staff
vital22re's Avatar
You can never have too much power.
Old 10-18-2014, 08:11 AM
lemonth68's Avatar
Okay, its been several weeks since I've been able to update. Took two weeks to get the heads back so we got the fuel pump, sending unit, and stall in. My brother took a few days off work to finish up. Thought today we would get the turbo and intercooler in but...guess the 80mm is too big! Had a 76mm but sold it for an 80mm and now we need the 76. Guess that's the way it goes sometimes.
Attached Thumbnails 2010 camaro ss build-forumrunner_20141018_111012.png   2010 camaro ss build-forumrunner_20141018_111051.png   2010 camaro ss build-forumrunner_20141018_111112.png   2010 camaro ss build-forumrunner_20141018_111134.png
Old 11-02-2014, 12:48 PM
mike1202002's Avatar
How much boost are you guys looking to put to it? Auto or 6 speed?
Old 11-02-2014, 02:48 PM
lemonth68's Avatar
Auto trans. Not sure on the boost. I would say not a whole lot a first due to seeing how the car will hook and the low profile street tires and large wheels but after the tune I think 8psi would be about right. But other things to consider is the cv axles and drive line. My brother had to get a smaller turbo and we are getting the manifold customized still. He has a good friend who can tig very well is working on that at the moment. Sorry for lack of pics. I've been busy at work and haven't spent much time on it with him lately. I wonder was its not an ls3 with the auto but a l99? After the conversion to get rid of variable timing and such it becomes ls3. The 6 speeds don't have any of that on them
Old 11-04-2014, 04:30 AM
Yeah I'm not sure on the differences between an ls3 and l99 but it will be interesting to see how the auto and axles hold up. I'm sure there are after market cv axles I know there were for the 03-04 cobras. But as long as a set of slicks aren't thrown on it I imagine the tires will spin before it would ever break an axle. But you never know.
I'm sure it will probably put down at least 550 on 8 lbs maybe closer to 600, a few wide open frenzies and that auto might be begging for mercy.
Old 11-04-2014, 05:34 AM
lemonth68's Avatar
Appreciate the interest. I should have updates with pics up by this weekend. Transmission should be okay for a short while. Camaro5 has some turbo ls3's but I haven't read a whole lot about them on there. I'm ready to see how its going to pull on the dyno. Dyno will tell us the weak links. I will post the dyno sheet
Old 11-08-2014, 01:33 AM
BigBluePile's Avatar
Looks like a fun project!!!!!!
Old 12-05-2014, 12:35 AM
lemonth68's Avatar
Finished and ready to take to dyno.
Old 03-17-2015, 12:36 AM
lemonth68's Avatar
Okay, its been months since update. Car has 600rwhp on pump gas. Had issues with torque converter and transmission shift points but its all fixed now. Getting ready to change injectors and fuel pump out, again, to run E85.
kawazx636
10-06-2021 03:03 PM
LittleUgly
15
01-02-2020 01:30 PM
myotherrideisayoshi
09-29-2015 05:41 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 2010 camaro ss build
