2000 camry wont start
I have a 2000 carmy an I left work a couple weeks ago an without warning it died. The low oil pressure light came on an the battery light. The car had plenty of oil an water. They car will crank over but will not start. It's getting spark and I hear the fuel pump. It will not start even with starting fluid. It has a cel for a cam sensor but I pulled it out an test it it with a voltage meter an it tested within spec. This things much different than my 22re I'm used to working on. I also pulled the clip that connects to the crank sensor an it tested to spec also. The timing belt was just changed about 10,000 miles ago.. Any ideas? Troubleshooting advice?
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
