Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
1961 Willys CJ-5
Old 12-31-2011, 04:35 PM
peow130's Avatar
Check to see what axles you have.
A 61 should have an offset rear dana 44. I believe theyre 19 spline that year, later years switched to centered up with a dana 20 Transfercase.
Your front will most likely be a stock Dana 27 closed knuckle.
Stock F head four cylinder?
Stock 3 speed? Twin stick transfer case?!?
I have a 51 CJ3A (Actually it's a CJV35-U, special order USMC Cj3a)
Check to make sure you don't actually have an old m38a1, which is a cj5 but titled as a street rig.
Old 12-31-2011, 07:32 PM
Janderson31R's Avatar
It has the stock F head Stock 3 speed Stock twin shift. Not sure about the axles but im pretty sure those are stock. How can I tell if its an m38? I know nothing about jeeps and even less about old jeeps.
Old 01-01-2012, 12:47 PM
peow130's Avatar
check out earlycj5.com, theres a wealth of information that you'd be well reserved to go look through
easiest way to tell if it's an m38a1 is if it has no tailgate, and the spare tire carrier is on the rear, not the side
also
look for the recess in the passenger side between the front fender and the door opening, recessed headlights into grille, evidence of military nomenclature tags on the dash, along with the weather proof multi function headlight switch, also look on the cowl, the twin 12v batteries connected in series for the 24 volt electrical system.
Ol'Greeny
12-17-2014 01:32 PM
TheLastViking
06-22-2014 01:21 PM
Quick Reply: 1961 Willys CJ-5
