irab88's Motorboat and Trailer Build-Up Thread
Wow. I just caught the picture on "post your pics" and had to look for the details. I really like the lines of the boat. Is it from the '60's? The trailer looks like it is vintage too. I bet it really strolls with the 40 HP. Back when I was working on mine I found the restoration forum at iBoats really helpful. There were a lot of build threads. They also have a Johnson motor forum.
http://forums.iboats.com/boat-restor...ull-repair-22/
yeah, the hull is 1963, and the trailer is 1977. the trailer is in decent shape, just needs a new coupler, wheels, and lights. the boat needs a desperate cleaning, maybe some paint, and new/re-covered seats. the engine needs to have its pull-start re-wound and fixed (it's jammed right now) and probably a carb overhaul.
thanks for the link, i'll have to check it out. i want to learn as much as i can about all of this so i can get some use out of it (hopefully this year).
since you've been around boats for a while, maybe you can answer this: is that engine a 2-stroke? not too sure. i'll check the iboats forum (that's like the pirate4x4 of the boating world, right?)
Yes it's two stroke. They are not sold in U.S. anymore due to EPA regulations. You probably know you have to mix your gas/oil 50:1. They are noisier than the new 4strokes but a whole lot lighter. I have a 2005 Johnson 25 hp. They stopped making the Johnson mark about that time but they are one with Evinrude. Bombardier Corporation which I think is Canadian. Most of the parts are interchangeable between Evinrude and Johnson of equal HP's.
IIRC you are an Eagle Scout. Did you ever go to Bayport? My sons are headed there this weekend for the Mariner program!
so after a bit of searching and some help from the wonderful people of iboats forum, i have searched around a bit more. i now know that the motor was made in 1985, and could possibly have an electric starter and/or external oil tank, which would be cool. i really need to open the engine up and have a look inside.
also, i found a few boat ramps around my area that'll dump into either the chesapeake bay or pax river, though i'll probably stay off the bay until i get more comfortable with the craft.
From the Fiberglassics forum:
1.) 5 of the 7 original astronauts owned Hydrodyne boats.
2.) A large photo of a Hydrodyne hung at NASA headquarters for years.
3.) Jacqueline Kennedy took delivery of a 1963 Hydrodyne the day that President Kennedy was shot and killed. To our knowledge that boat is still somewhere on the Maryland shore.
"Jacqueline Kennedy took delivery of a 1963 Hydrodyne the day that President Kennedy was shot and killed. To our knowledge that boat is still somewhere on the Maryland shore."
Maybe you should name your boat "Camelot."
I ordered blue silicone trailer rollers from iBoats a couple of years ago when I was working on my boat trailer. IIRC I got them during a huge sale during winter. They were inexpensive and cheaper than those clear/yellowing silicone rollers most new boats have. They look pretty sharp. If you have questions about the motor the mod usually responds with a copy of the exploded diagram parts page and an estimate on the price.
wha... oh, wow... uuum... so...
hull number check? owner history? how? this is something i'd like to find out!
popped the top, doesn't look too awfully bad for a 28 year old motor
i'll check that bottom cylinder for water ingress
first on the list: fix that damned pull cord. also, the flywheel seems to have marks from a starter gear. maybe in the future i'll try installing one
Nice boat, those are good Johnson motors. The first thing I would do is get this http://www.westmarine.com/webapp/wcs...1#.Udtk9cu9KSM and change the lower unit oil.
Hopefully no water comes out...also, beg, borrow and steal to get electric start on that. It's the best thing I did to my 14 footer. Should be plenty of parts still kicking around for that motor.
Finally, Nervo, what's this about no 2 strokes being sold in the US? You can still get new 2 strokes, maybe I misunderstood.
no 2-strokes over a certain size, i think
and thanks for the info, it'll be nice to start digging into the motor to find all that's wrong with it. these motors are still available, so no issue on parts
as for the starter:
http://www.ebay.com/itm/NEW-STARTER-OMC-JOHNSON-EVINRUDE-OUTBOARD-384163-387684-389275-585063-586280-/360478970598?pt=Boat_Parts_Accessories_Gear&hash=item53ee3892e6&vxp=mtr
http://www.ebay.com/sch/i.html?_odkw...er+40&_sacat=0
as for the starter:
as for the starter:
New Starter OMC Johnson Evinrude Outboard 384163 387684 389275 585063 586280 | eBay
as for the starter:
Evinrude and Johnson are like GMC/Chevy, as are Mercury and Mariner. BRP owns Evinrude now, but still sells Johnson parts. They probably still support that motor. They also own Ski Doo, who makes some sweet sleds.
found out that vro is an option, but not without a $400 price tag
so i think my non-vro will do just fine for now
and for my reference:
http://continuouswave.com/whaler/reference/VRO.html
Sweet new2U boat Ian... a little work and you'll be set... don't forget to put in the hull plug before you launch her... everyone does that at least once... I'd consider also getting a small elec. bilge pump... they can save you if you get caught in bad weather or get swamped by some jerk's wake...
Johnson/Evinrude are very good reliable motors my Grandpa always swore by them though he preferred the Evinrude version...
Irab, if you go to "google images" and search for "Hydrodyne" there are a lot of pictures. I thought the J.F.K. connection was pretty funny. If you look for "JFK boat", you're going to get a lot of PT-109.
