Motorcycles Motorcycles of any kind including ATVs
Any ATV gurus? Suzuki quadrunner 500 4x4 questions
Old 08-29-2007, 08:45 AM
gilby4runner's Avatar
I just bought it and love it. Its a 99 with 621 miles. I do have a few questions for those who might have some answers..
1. It pulls to the right. I have checked the air pressure and it is equal between the two front tires. I sags a little to one side. Both shocks are adjusted to the same setting but there is a 1/16 - 1/8 difference in the spring length at this setting. Should i have the toe checked and possibly adjusted? It might just be a trick of the eyes but it looks to be a little out.
2. Any suggestions on tires? I want something for trails and some gravel roads.
3.I have purchased the stuff to change the plug, oil, and air filter. Anything else i need to do?
Old 08-29-2007, 08:46 AM
CJM
CJM's Avatar
Bleed the brakes and check to see if one of the calipers is sticking.
Old 08-29-2007, 09:49 AM
thanks CJM- I'll check into that tonight
Old 08-29-2007, 12:09 PM
Old 09-01-2007, 07:45 PM
chrishf12's Avatar
its probably a simple tie rod adjustment that will stop the pulling.
Old 09-01-2007, 09:08 PM
CJM
CJM's Avatar
Any luck?
Old 09-01-2007, 09:17 PM
the_gunslinger's Avatar
measure the toe yourself. use the wheel's to measure, and make sure the wheels are straight.
take it for a ride only using the rear brake, then check if one of the front disc are warmer/hot.
Old 09-02-2007, 02:16 AM
91muddog's Avatar
just want to say, i have a 85 quadracer, would not trade it for anything.
they are good bikes.
have fun and gl man.
coleypull15
11-03-2015 07:41 AM
Alex Bessinger
08-31-2015 09:17 AM
Tyler Cunningham
07-11-2015 10:18 AM
Coreyr384
07-10-2015 11:13 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: Any ATV gurus? Suzuki quadrunner 500 4x4 questions
