WTB: 22RE Idle Air Control Valve
I'm looking for the IACV/AAV for my 87 4runner. The bi metal tab in mine no longer moves so the valve is stuck closed.
Here's a bad photo of mine....basically, it's mounted to the top intake piece by 2 bolts, just below/behind the throttle body. It has an air hose coming into the front, and out the back, plus an in/out pair of smaller water hoses (that's a water hose in the photo). It also has a wiring harness plug on the backside of it (toward the cab).
If you have one lying around and can verify it WORKS (is open when cold, closes when hot water is poured through the water ports), I'm intersted. Located in SF Bay area but would pay to ship USPS.
Thanks
Phil
Thanks
Phil
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
09-04-2015 09:27 AM
