Wanted: Wiring harness for 1990 Toyota Pickup 22re 4x4
I'm looking for a wiring harness for my truck. It's wiring is all cut up and it barely runs. Half the wiring isn't even connected. It was all chopped and they tried to re-do it til it ran. So if anyone has a wiring harness that's compatible with the 1990 22re 4x4 truck, that'd help a lot!! Thanks.
Wiring Harness
Pre 89's are not going to plug into your fuel injectors or TPS for staters.
I think you have to find 89-92. IIRC our Friends at Toyota change the harness again for 92-95 with diffenet igniter and dist connectors as well.
hoping to find one that mated to the ecu with part number 89661-35150
Thanks for the info. This will help in my quest greatly so that I don't have to rewire stuff. ^_^
Ok, I have one but it's a auto harness which will work, all you will have to do is jump a wire on the harness itself for the starter, which I can do for you.
How much do you want for it? Would the reverse lights still work too? I've seen problems with reverse lights when using auto harness on manual vehicles. Let me know.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
TheManOutside
06-18-2015 03:32 PM
