MISC yota parts
MISC yota parts
I will add and delete as I find stuff and sell stuff.
4cyl Tcase. Stock gears. Interlock pin has been removed. this case has the longer forward shift rails. Not for W56C or D transmissions. Transmission must have the 2 separate shifter bases for this tcase. $50
Homemade Ubolt flip plates. Same dimensions as the ones you can buy online without the angle on the front. These are flat 1/4 plate. For front axle or rear 1st and 2nd gen. Will not work on 3rd gen axles - they have wider spring perches. $20
Homemade Ubolt flip plates for 3rd gen rear axle. I had these made from 3/16 plate and they are wider than the ones you can buy to fit around the wider spring perches. $20
22RE intake manifold. Upper, Lower, Throttle Body, fuel rail, some vac lines, some VSVs. $40
Blower motor from an 87 runner. It works. $20
All prices are OBO and do not include shipping.
Also have these revolver shakles for $30. Top bolt is 18mm (stock yota size) Bottom is setup for chevy springs. With these shakles, you wont have to move your rear shakle hanger.
The top bolt is the same (18mm) that you can get for any of the shakles from marlin, all pro, trail-gear, etc. The bottom bolt is the OEM chevy 9/16 bolt. What is in the picture is all I have. I believe you can even use the stock toyota shakle in place of the included top shakle.
Regency
20
01-03-2020 07:43 PM
09-04-2015 09:27 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
