4.88 Ring & Pinion $130 Shipped from Fort Lauderdale, FL **sold**
Old 05-18-2013, 05:55 PM
coryc85's Avatar
4.88 Ring and Pinion 8in, 4cyl variety, just removed from my truck. Seem to be in good shape, but unknown overall mileage. Will also include a new pinion seal from the Trail-Gear setup kit, a new pinion nut, and a crush sleeve. Could also throw in the used bearings if you want them. From reading Zuk's website, the markings lead me to believe these are the old Genuine Gear brand gears. These were set up with an .081 pinion shim, which I can also include if you'd like, but I did not check the pattern to verify that it was correct, although the gears were not loud or anything.
Markings on the pinion
Markings on the ring gear
File Type: jpg
File Type: jpg
Old 06-10-2013, 09:49 AM
coryc85's Avatar
BUMP - open to trades as well.
Old 07-01-2013, 11:49 AM
coryc85's Avatar
BUMP - I was thinking about some things I could use in trade...
- new(ish) 22re radiator
- 4runner poly body bushings
that's all I can think of right off.
Old 08-30-2013, 07:14 PM
KBar's Avatar
I really need those gears been looking at all my local junkyards and all the yota part out ads on craigslist. Money is kinda tight for me but I have alot of yota parts if your willing to trade just let me know what you need
Old 09-01-2013, 07:19 PM
funnymeatball's Avatar
Any Idea if this should swap out with the 4.10 gears in the v6 diff?
Old 09-01-2013, 08:04 PM
twistedyota's Avatar
Yea the 4cyl gears will fit in your v6 diff, you will need to add an extra .100" or so in shims to the pinion, just added 4cyl gears to my v6 housing.
Old 09-02-2013, 08:11 AM
Can you do 100 shipped to venice, fl?
Old 09-02-2013, 11:09 AM
coryc85's Avatar
funnymeatball - I believe KBar and I have reached a deal, I will contact you if for some reason it does not work out.
Thanks!
Old 09-17-2013, 02:39 PM
702yota's Avatar
4.88
still got gears lmk
Old 09-17-2013, 05:41 PM
coryc85's Avatar
PM'd you 702.
Old 09-30-2013, 10:23 AM
raevenzero's Avatar
Still available?
Old 10-01-2013, 12:29 AM
Fito760's Avatar
Is it still available?
Old 10-01-2013, 05:21 AM
coryc85's Avatar
Sorry guys, guess I was not subscribed to my own thread. The gears are sold, thank you for your interest.
coryc85
09-09-2015 06:24 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
jaretstuff
08-04-2015 02:08 PM
KyleT
07-21-2015 07:54 PM
coryc85
07-07-2015 04:05 AM
Quick Reply: 4.88 Ring & Pinion $130 Shipped from Fort Lauderdale, FL **sold**
